'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
OIL CATCH CAN D-I-Y
SIMOTA OIL CATCH CAN INSTALL
I put this on MicroImage from my phone. most of us have log-ins over there to view the images....let me know if I need to port this over to here instead of linking to it....
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
Looks good. I tried a few different catch cans, and could not get my car to run without throwing a CEL. I did not try the Simota. Hope yours works well.
Hopefully....
Really nicely done, very clean.
![]() ![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
clean!
One of two is doing fine. The one on the 2012 is flawless. Mine, the 2014, I keep getting p0171 for lean. Do I have a dud, or does a catch can reading change the vacuum readings that much?
You must have a leak. If everything is sealed it should not have an effect like that.
Yeah, is weird as everything is tight. I don't have a smoke machine to check for leaks, but I still suspect that the pcv nipple being able to slip out of the silicone tube even with the hose clamp tightened is the culprit, yet I now have two clamps on it and a spacer between the tube and clamp.... Maybe a smaller diameter tube is in order....
I'm hoping I found the leak. The breather tube from cc to intake had oil seepage around large nipple on air intake, it was clean yesterday. Where there's fluid there's going to be an air leak....
No go still.... waiting on wife to bring home PTFE tape... Going to remove inlet & outlet ports and apply the tape, also to drain plug.... Here's to going it works....
How is the can constructed? Does it have an inner plastic container or is the the sight window bonded to the aluminum?
Looks to be sealed, dual windows on aluminum.....
That might be worth testing as well. Stick a finger over the two fittings and hold it under water and look for bubbles.
#14 |
Yeah, testing of the unit will come today.... I added PTFE to the three ports... The code hasn't popped yet, but it is showing as pending if I'm reading the code reader correctly.
#15 |
Alright, I found the leak.... It's coming from the lower shiny end cap where it mates to the main cylinder.... I'll post a pic in a few....
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
