Old 09-09-2013, 04:04 PM   #19
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
^ You think that vibration, transferred by a rubber belt, broke a water pump pulley?
No. I only know that solid undamped crank pulleys vibrate. What happens after that is anyone's guess.
Old 09-10-2013, 02:15 AM   #20
Astroman
Modded Moderator
Astroman's Avatar
I wanted to update that now my Yaris has a cracked NST water pump! I put mine on more than 90k miles ago and my car has been unused for the past 9 months. After a rough start and replacing a dead battery and what I thought was a bad thermostat I noticed that after a few hundred feet my water temps were so high I threw a CEL and my hot light came on. After hearing clacking I looked thinking of this thread and sure enough in one spot it's cracked! Not happy with NST and I KNOW FOR A FACT MINE WASN'T OVER-TORQUED because I've had it problem free for 90k miles!
Old 09-10-2013, 02:31 AM   #21
B2FiNiTY
B2FiNiTY's Avatar
Drives: Prius C
sounds like it simply wore out.
90k miles is pretty good usage for an aftermarket part if you ask me.
B2FiNiTY is offline   Reply With Quote
Old 09-10-2013, 02:33 AM   #22
I think their "hard anodizing" may have weakened the metal or made it brittle. It's pretty thin where is bolts to the motor.
Old 09-10-2013, 02:46 AM   #23
tooter
play every day
tooter's Avatar
Are you running the stock crank pulley?
Old 09-10-2013, 09:18 AM   #24
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Sounds like they designed it too thin or didn't machine it right.
Old 09-10-2013, 02:47 PM   #25
Astroman
Modded Moderator
Astroman's Avatar
I'm running the full NST-lite pulley set problem free until yesterday. The wp pulley had a wear groove of about 1/16" and I wouldn't have known it was cracked if I hadn't been having overheating issues. My overheating turned out to be no coolant in the radiator.
Old 09-10-2013, 05:54 PM   #26
Bluevitz-rs
Where'd the coolant go?
Old 09-10-2013, 08:40 PM   #27
weedtank
I need more stars
weedtank's Avatar
Drives: Liftback
We all know the moral of the story here..
weedtank is offline   Reply With Quote
Old 09-11-2013, 03:50 PM   #28
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
I'm very surprised at the responses this thread has gotten.
I think i'm more surprised I haven't heard of this happening before.
Definitely sounds like a design flaw in NST's pulley's, something is making them brittle and weak.
I was going to try and get another one from NST, but since everyone else seems to be having the same responses...it might be best to stick to OEM.
Black_griffin6 is offline   Reply With Quote
Old 09-11-2013, 04:23 PM   #29
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
makes me want to check my w/p pulley.....i hope it's ok! it's been on for quite some time.
goliath1812 is offline   Reply With Quote
Old 12-29-2013, 01:15 AM   #30
Terrorize
Toyota Newb!!
Drives: Yaris S Sedan w/ Aero Package!
I had a similar experience in that there was a lot of belt squealing and vibration....and then the belt eventually snapped. Turns out it was the NST WP pulley as well...after reading the problems you had I was going to switch back to OEM and this happened.
Terrorize is offline   Reply With Quote
Old 12-29-2013, 04:41 PM   #31
tooter
play every day
tooter's Avatar
Sorry to hear that, Terror... This is why I like the stock crank pulley because it damps crank vibrations.
Greg
Old 12-29-2013, 04:57 PM   #32
Bluevitz-rs
I've been running my Perrin crank pulley for 8 years and have 140000 km on it with absolutely no issues. I've seen the stock pulleys fail too where the rubber rots and the outer part falls off, so six of one half dozen of the other.
Old 12-30-2013, 02:56 AM   #33
tooter
play every day
tooter's Avatar
Fair enough, Blue. There will always be different opinions drawn from each of our own personal experiences.
Greg
Old 12-31-2013, 12:39 AM   #34
TOLMACH
Drives: soarer
^ (pics above)
Wow ((
Old 01-02-2014, 08:31 PM   #35
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
I have heard too many downs and not enough ups for any pulley changing. Stock for me.
Old 01-02-2014, 11:16 PM   #36
I don't think any downs from our Micro Image crank pulley. I'd like to keep our product separate in terms of reviews, unless someone has broken one of ours -- then I want to hear about it. Lumping all the crank pulley options together doesn't fit the evidence, in my opinion.
WTB: NST Pulleys *MAD DOG* Willing to Buy by private party 3 08-27-2011 04:37 AM
NST (NonStopTuning) Ebay Feedback & Rating NonStopTuning NonStopTuning 0 07-19-2009 11:11 PM
Greddy TI-C, NST Pulleys, etc. drkmcc Items for Sale by private party 12 02-12-2009 07:05 PM
NST Pulleys + Automatic Transmission WeeYari Performance Modifications 17 01-31-2009 01:29 PM
Drift Yaris + NST Pulleys = :) thefoth Performance Modifications 20 11-20-2008 10:03 PM
