#19 | |
#20 |
![]() Drives: 2007 yaris liftback Join Date: Jan 2014
no, they were plug and play. I also had a module spliced in for trailer lights...thought maybe it went bad so i disconnected but the crimp down connectors are still in place. maybe causing issue? also, i reconnected the original factory assemblies and problem still exists
#21 | |
#22 |
...just checked...doesnt seem to be..is there a possibility this is a relay/fuse issue? also...i've never been a fan of those crimp connectors..do u know what color the ground wire would be on the harness that plugs into tghe rear tailights? i may remove connector and try to splice it back with a tube type connector
#23 | |
For fuses that could potentially be involved, the 10A GAUGE fuse feeds the coil side of the blower and the coil side of the rear defogger. The 10A Tail fuse feeds the tail light bubs and all of the illumination circuits.
#24 |
the module for trailer lights had its own ground wire that attatched directly to the car. in other words it didnt tie into the tailight wiring harness like the others so i'm guessing the white/black ground is undisturbed. im thinking of removing all the crimp down connectors, cutting the wires, and then splicing them back together. if that doesnt work i'll start checking fuses and/or relays i guess...not sure what else....
#25 |
TO: CTScott
Thanks again for all the help..just wanted to let you know i've fixed the problem and it WAS the 10amp Gauge fuse...here's the thing though. that was the FIRST thing i checked before i even sought out this message board for help. when i examined it, the filament wasn't broken, fuse looked good. however when i tested it with a multi tester while it was still in place, it read full voltage on one side, only half on the other. replacing the fuse fixed everything. it was bad, but not "blown" to the naked eye |
#26 | |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| 2007 Toyota Yaris Hatchback - 5-Speed Manual | truebreakerz | Cars for Sale by private party | 23 | 09-17-2009 09:29 PM |
