Old 01-31-2014, 07:53 PM   #1
lablancjc
Drives: Toyota Yaris S
I have a leak
I have read about some leaks but the pictures were not so clear on where the leak was. I am posting these pics up so you guys can help me identify what the leak actually is. If you need more pics let me know I will take more and post!
There is no oil above the crooked line all oil is below
I had this done under warranty last June
Any help will be awesome I think that would be the timing cover but could be wrong. Thanks in advance.
lablancjc is offline   Reply With Quote
Old 01-31-2014, 09:21 PM   #2
LuisPRTRD
Angry Bird
LuisPRTRD's Avatar
Drives: yaris sedan
looks like the timing cover
LuisPRTRD is offline   Reply With Quote
Old 01-31-2014, 09:46 PM   #3
The leaks discussed in the other threads were at the head gasket. Yours does look to be at the timing cover again.
Old 01-31-2014, 11:55 PM   #4
Hershey
As stated above it's likely to be the timing chain cover . We did some research on the internet and discovered this is an issue for some Toyota models over the years . Therefore our conclusion is that the oil leak we had for the '08 sedan and 2010 3 door ( traded in for '11 Fit ) was the timing chain cover and not the head gasket . We did point this out to the service manager that was discovered online , copied and presented to only to be told you can't believe everything off the internet . Here's the '08 sedan with the leaky timing chain cover ( http://www.carsurvey.org/reviews-by-.../2008/#r125809 ) and a few others that followed with oil leaks ( http://www.carsurvey.org/reviews/toy...5809/comments/ ) . So , the Toyota technician decided it was the head gasket and went with their diagnosis for our '08 sedan . No leaks as of yet since the head gasket replacement in September of 2010 and 45,000+ miles ago . Read somewhere online that the white sealant from the factory isn't as good as the black silicon sealant ( F.I.P.G.) . The Toyota black silicon sealant was used by the Toyota service center for the repair and no oil is leaking from the timing chain cover or other areas .
Old 02-01-2014, 12:29 AM   #5
Hershey
Pictures : May need to Zoom in for last 2 pics .
Old 02-01-2014, 12:05 PM   #6
Hershey
Took these today .
Old 02-01-2014, 11:41 PM   #7
lablancjc
Thx a bunch guys I will be notifying the dealership who did the work. Hopefully they will repair it since they either did the work shotty or Toyota needs to do a recall.
Old 02-06-2014, 11:30 PM   #8
jdmjavier
Drives: yaris sedan 2008
me pueden decir el enlace hilo de fugas.gracias
jdmjavier is offline   Reply With Quote
Whistle at idle - vacuum leak, induction side RichieRoo General Yaris / Vitz Discussion 17 12-16-2022 06:53 AM
Newbie with an exhaust leak on his '06 Yaris ToYarta DIY / Maintenance / Service 49 01-03-2019 01:50 PM
Just a Wee exhaust leak WeeYari DIY / Maintenance / Service 12 09-02-2015 04:24 PM
Head Gasket Leak Hershey DIY / Maintenance / Service 45 11-11-2010 11:19 PM
Where is my oil leak coming from? The Gearbox? MarkBond General Yaris / Vitz Discussion 1 08-25-2007 11:31 PM
