![]() Drives: yaris Join Date: Feb 2014
Need Help to change Muffler
Hi Guys ,
Have a nice day My car is 2007 Yaris Sedan 1300 CC I want to change my muffler to get deep and solid tone on the car . i found a muffler on ebay :http://www.ebay.com/itm/171035094830...%3AMEBIDX%3AIT this is the specification : Muffler (Silencer is included) Style: N1 Slant Tip Material: SUS304 / T304 Stainless Steel Color: Chrome Burnt Muffler Body : 12 Inch Outlet Tip Length: 4 Inch Outlet Diameter: 4 Inch Inlet Tip Length: 2 Inch Inlet Diameter: 2.5 Inch and i see that the inlet of the muffler is 2.5 inch and my yaris exhaust pipe is 2 inch or may be less than 2 inch . is someone know what is the exhaust pipe size for 2007 yaris sedan 1300 cc ? and my question is how can i change the oem muffler to this muffler that have different size of pipe ? and i dont want to make down the power of the car please help me to change the muffler the exhaust system is same as the attached photo thanks and best regards Last edited by sobri46; 02-11-2014 at 01:47 PM. |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
If its anything like ours...the stock tubing is 1.75"
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
if the 1.5L has 1.75" exhaust piping (pre-muff), then the 1.3L version of the same engine model should have a smaller one.
and my question is how can i change the oem muffler to this muffler that have different size of pipe ? you can only go as far as 0.25" increase to not lose noticeable amount of torque, unless you have a turbo that needs to flow a lot of air out. on the same note, a 2.0 inlet muff can be the biggest you can go, 2.5" will be overkill (for a perspective, turbo'ed 1.6L engines only use 3.0") although just changing the muff will not significantly affect the powerband, it will still. 0.02 |
thank you for your reply,
i think you are right that may be the exhaust pipe of my 1300 cc yaris will be less than 1.75 inch and may be it will be only 1.5 inch if i will just cut the oem muffler, then make an adapter from 1.5 inch to 2.5 inch and add 2.5 inch pipe about 10 inch only to fit the long of the pipe after remove the old muffler and then put the new 2.5 inch muffler with out changing any other OEM pipe or resonator or header . do this modify will be good and will not changing the power of the car ? i just want to get a good sound and not looking for increasing of more power or HP for the car. the problem is i don't find any good 2 inch muffler on ebay . please help me to resolve this matter thank you |
| Yaris vs Celica | jesh462 | New YARIS Purchase Forum | 11 | 10-18-2012 11:49 PM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
| Yaris TRD Sport Muffler | ArtS | Items for Sale by private party | 3 | 11-30-2010 09:43 PM |
