#19 | |||
![]() Quote:
#20 |
![]() ![]() Drives: Vitz S 2007 LB Join Date: Feb 2013
You have somebody in japan that helps you to ship them? Can you do a direct shipment to malaysia instead of routing it to us then to malaysia? It would be a round the world for that item, lol
#21 |
I'm not sure. What's the part you have in mind?
#22 |
Exhaust, headers, bodyparts, 4wd tranny set...
#23 | |
![]() ![]() ![]() Drives: Yaris Hatchieback Join Date: Jun 2010
I just wondering what if I delete second cat and resonator with 2.5 all the back to TRD muffler. I believe i will lose little bit of low end and got more high end. Also, I got DC 4-1 header. Any suggestion or has anyone done it yet. |
#24 |
would losing the 2nd cat lose low end?
#25 |
![]() ![]() Drives: 2002 Toyota Yaris T-sport Join Date: Jan 2014
There are 2 cat's on these toyotas? No way.
Losing any cat increases torque, since it's basically a really thin straw the engine tries to breathe through. You might have issues with the emissions test though.
2002 Toyota Yaris T-sport ![]() 198X BMW E30 modified race car ![]() 1975 Ibanez "Les Paul custom" |
#26 |
The second one isn't as important as the first one, but I wouldn't remove any of them.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#27 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
The flow is already set by the first cat...so removing the 2nd cat is only going to gain more noise then power.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#28 | |
#29 |
Yes, thats the stock yaris exhaust system that is on everyones beloved, including mine. I wouldnt mind removing the 2nd cat if it does increase torque in anyway, besides in malaysia there is no such a rule for emisions... the rules here are all bendable. Can anyone here prove that removing the 2nd cat increases or decreases power?
2nd issue is, i want an axleback exhaust, but i just cant find any here in malaysia, so it would have to be custom. Any suggestions? Mine is an automatic,. 3 issue is, changing the cat, i would like to change the 1st cat to a high flow, any suggestions on that too? Thanks guys |
#30 |
Isn't it 1 cat and 1 resonator, not 2 cats?
#31 |
^ No. Look at the diagram, you'll see both cats before the resonator (#5).
#32 | |
#33 |
Had this installed yesterday... noticeable gain in torque and reduction in engine grunt, especially when uphill drive, and much more smoothness, i mean it wont hold back the car when i release throttle....
Its a 4-2-1. |
#34 |
![]() ![]() ![]() Drives: 2012 Grey Toyota Yaris SE Join Date: Dec 2011
Weapon r header?
Upgrades: AFE SRI. Tanabe Touring Medalion Axleback exhaust. Micro Image OEM Sized Lightweight Pulley. DC Sports header. |
#35 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
No. But it's a smoother flowing design than weapon R...
![]() Who makes that? Greg Last edited by tooter; 02-17-2014 at 12:35 AM. |
#36 |
A company here called undersix exhaust. Malaysian made.
And its very light... |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
| Aftermarket exhaust systems that do not rub on the road! | fuji | Performance Modifications | 10 | 04-28-2009 06:22 AM |
| Performance exhaust systems for yaris | aucorium | Performance Modifications | 6 | 08-16-2006 08:12 AM |
