![]() Drives: 2006 Scion xb Join Date: May 2013
Blitz fuel controller wiring questions
Need help with an install of a Blitz supercharger on a 2006 Scion Xb. Blitz's online instructions appear to be for the 2004 and 2005 only. Also the fuel control box has 9 wires and the instruction show it as only 8. Seems that my fuel control box has a light green wire not shown in the instructions. Can anyone clue me to what function each of the 9 wires controls so I can attach them to the ECU in the correct location for the 2006. You Yaris guys are the most knowledgeable when it comes to 1NZ-FE performance info. Thanks.
Can you post pics of what you have? Does the fuel controller have the 8 pin connector with an second wire in one of the 8 positions?
Also, the instructions for 04-05 should be fine for your 06, as 04-06 all used the same ECM configuration.
The connector has 12 spaces for contacts but only uses 9. Top row is the same as shown on the instruction but starting with two vacant places followed by pink, red, yellow and then orange. Second row has one vacant space followed by the extra light green wire not shown in the instructions, the dark green, the black, the blue, and then the white wire. I also got a spare fuel control unit when I bought the Blitz used and it's wired identical to the first.
#4 | |
1. empty 2. empty 3. Pink - IGF (RPM) 4. Red - Ignition switched power 5. Yellow - Injector #2 6. Orange - Injector #1 7. empty 8. Light green - VG (MAF Sensor output) 9. Green - To blue activation harness wire 10. Black - Ground 11. Blue - Injector #4 12. White - Injector #3
Thank you....Thank You.....THANK YOU!!!!!!
This is a tremendous help! I'll forward this info to my tech....have a feeling I'll be getting boost soon. Physical install went fairly smooth, but this has had us scratching our heads. Again, much thanks! |
| Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 327 | 01-02-2026 11:44 PM |
| Boss HU wiring questions | Nodrog | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 01-29-2011 11:16 PM |
| Boss HU wiring questions | Nodrog | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 01-29-2011 07:18 AM |
| FS: $250 + Shipping - BRAND NEW Blitz R-FIT (Fuel Intensity Controller) | Ran Kizama | Items for Sale by private party | 8 | 09-06-2007 04:26 PM |
| Low fuel light | falkor_99 | General Yaris / Vitz Discussion | 35 | 08-24-2007 03:20 PM |
