Old 03-26-2014, 04:33 PM   #1
barefoot_bajan
barefoot_bajan's Avatar
Drives: 02 vitz rs
need help. engine making ticking/lifter noise
engine 1nz-fe... oil. 10w-30... serviced every 3 mths
but i've noticed that i'm getting noise from the lifters but only when i'm in traffic or after long drives.
car doesn't hesitate or stall or any of the weird stuff, the crap gas we have causes it it pink which is really bloody annoying but that's about it.
any ideas?
thanks in advance
so many pedestrians..... so little time
barefoot_bajan is offline   Reply With Quote
Old 03-26-2014, 04:56 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
could be your water pump..check inside the pulley if you got pink stuff leaking.
Old 03-26-2014, 05:48 PM   #3
Lifter noise is normal for our engine. It becomes more audible as the oil gets hot and loses its viscosity. Running a higher viscosity oil would likely help, but would then cost you a bit of fuel economy.
Old 03-26-2014, 05:52 PM   #4
barefoot_bajan
Drives: 02 vitz rs
thanks marcus... thats the next on list to change
Old 03-26-2014, 05:53 PM   #5
barefoot_bajan
Drives: 02 vitz rs
i live in the caribbean... so 10w-30 is all i'm using
thanks ctscott
Old 03-26-2014, 10:54 PM   #6
barefoot_bajan
Drives: 02 vitz rs
Did I mention I'm also smelling Gear Oil periodically??
Making a engine wiring harness maxthehax Forced Induction Forum 14 06-02-2013 09:53 AM
Whining noise from engine bay when under load. rasper General Yaris / Vitz Discussion 2 05-07-2011 06:46 PM
car making cheap car noise the_boss Cosmetic Modifications (Exterior/Interior) 5 03-07-2011 08:05 AM
Helicopter noise from the engine??? jonr0613 DIY / Maintenance / Service 10 07-16-2009 06:56 AM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 10:45 PM
