Old 03-19-2014, 12:51 PM   #1
modmonster
Drives: Yaris
Wireless key entry stopped working
Hello people,
So my wife's Yaris 2006 model 1.0 litre 3 door horn wasn't working so I removed the integral relay to test it as per the instructions manual. Replaced everything back but now the key fob for wireless lock/unlock has stopped working.
I tried to follow the programming procedure few times but nothing happen.
Anyone has any idea what might be the problem?
modmonster is offline   Reply With Quote
Old 03-19-2014, 01:19 PM   #2
Try disconnecting the battery for a minute to reset the entire door lock system.
Old 03-19-2014, 01:41 PM   #3
modmonster
Drives: Yaris
Thanks CTScott, have already tried that and disconnected for about 5-8 minutes but still no success.
Old 03-19-2014, 02:00 PM   #4
Check the DOME fuse, which powers the door lock receiver.
Also check the ECU-B, D/L, ECU-IG and ACC fuses, all of which are involved in the wireless door control process.
Old 03-19-2014, 03:15 PM   #5
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
try opening the key fob and scrape the battery front and back and put it back on.. that worked for me.. and im still on the original battery since 07...
Old 03-30-2014, 07:24 AM   #6
modmonster
Drives: Yaris
Sorry for the late reply but been busy with other house chores :). Tried most things but no success however I noticed something, that is the dash clock does not remember the time. So once you set the correct time, if you switch the ignition off and turn it back on again the time is set back to 12:00.
I some how lay my suspicions on the integral relay which I initially removed and tried to open and since then all my problems have started. Could this be cause?
Old 03-30-2014, 07:40 AM   #7
The clock is tied to non-switched power to keep its time, so I would check your battery to see if the voltage is dropping very low (under 9 volts) when the starter is cranking.
Old 03-30-2014, 07:57 AM   #8
modmonster
Drives: Yaris
But the clock doesn't forget the time if I start the engine or even try to crank it. It's when I switch everything off that's when it forgets the time.
Is there a diagram or steps to test the whole integral relay with a multimeter?
Not sure if this is related but reading another post of yours I tested the following sections with the following Results (Test with really of the car, not sure if I need to do this while it's connected but it's probably not possible as the wires too short and can't access points once really is plugged in):
1A (2 & 3) = 0.2 ohms
1A (6 & 7) = 0.2 ohms
1B (2 & 3) = 0.2 ohms
1B (6 & 7) = 0.2 ohms
Car battery voltage is 12.2
Old 03-30-2014, 12:24 PM   #9
Ah, so it sounds more like the constant power supply to it is not there.
Check the DOME fuse.
Old 03-31-2014, 11:34 AM   #10
modmonster
Drives: Yaris
Al rite guys, this is now has been resolved. Note to self, next time take fuses out and put them back in do this when it's light and not dark. Appearntly I've replaced the main fuses on the left side incorrectly. I have done them all correctly now and everything's back to normal except for the Horn.
Thanks for your help and input all, saved my self £48.00 toyota checkup fee or maybe even £128 for a replacement integral relay :).
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
Smart key entry - battery problems. red-demon85 DIY / Maintenance / Service 5 10-24-2013 05:28 AM
Keyless Entry stopped working but buttons do work! worduphomes In Car Entertainment + Electronics (audio / video / alarm) 5 01-17-2013 09:35 PM
2007 Yaris Keyless entry key kev084 DIY / Maintenance / Service 1 07-03-2012 12:24 PM
I lost my master keyless entry key, need suggestions.... Frankd1 DIY / Maintenance / Service 19 12-01-2010 11:13 PM
