Old 03-31-2014, 03:53 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
does 3m tape work for side skirt
anyone tried 3m tape for side skirt would it hold? ,, broke a couple of pins which toyota dont have available for sale.
Old 03-31-2014, 04:44 PM   #2
kou
Drives: 08 lb
Yes 5yrs and still holding no pins just a thin strip of 3m tape down the length of the side skirt. I just added one extra screw underneath the rear, there was a factory screw hole there for something else.
Old 03-31-2014, 05:47 PM   #3
marcus
toyota
marcus's Avatar
good to know..thanks... so tape on the side and screw/bolt on each end..right?
Old 03-31-2014, 09:09 PM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
It did not work for me. especially if you take out the fender liner. The front tires will kick rocks past the fender and in the door jams between the top of the side skirt that lays on the rocker panel and the bottom of the door. small rocks would get between the side skirts and rocker panel where the tape was and over time would come loose. I ended up just drilling holes and using some flat screws to hold the side skirt firmly to rocker panel.
-Derrick-
Old 04-01-2014, 07:59 AM   #5
marcus
toyota
marcus's Avatar
Even when the skirt is screwed on both end.?
Old 04-01-2014, 08:37 AM   #6
3M should be okay. Sounds like you will be able to use tape in conjunction with the remaining pins you do have.
Old 04-01-2014, 08:44 AM   #7
ilikerice
ilikerice's Avatar
no, Just tape. I should have screwed it in first. After I screwed it in, it looked more flush and I didn't have any more issues. I do autocross alot and I have made some contact with a few cones in the past 2 years. If you have fiberglass skirts, be aware that rocks will eventually chip away the paint on them. I recommend using some form of clear vynl wrap on them to peek the paint together. Another thing I wish I did. My body kit is trash now..
-Derrick-
Old 04-01-2014, 10:30 AM   #8
^ 2007 RS, he has factory RS skirts.
Old 04-01-2014, 11:39 AM   #9
ilikerice
ilikerice's Avatar
well screw you guys and your OEM side skirts...
-Derrick-
Old 04-01-2014, 12:30 PM   #10
kou
Drives: 08 lb
I put a thin strip of tape on the entire top edge of the side skirt I didn't put any on the spots where the body pins go. My car was standard not an 'S' so no holes for them anyway.
Old 04-01-2014, 02:07 PM   #11
marcus
toyota
marcus's Avatar
ill work with 3m this weekend we shall see...
Old 04-01-2014, 03:14 PM   #12
My original style RS spoiler has been held on with nothing but 3M for 6yrs. Rock solid.
There should be no issue with a skirt (along with pins). Just make sure you heat the surfaces where the tape is to be applied with a hair dryer. You want it warm.
Old 04-03-2014, 09:54 AM   #13
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I zip tied mine on the ends and have the 3m tape down the length of the rocker panel, but it's only been a few months and its already starting to come loose. I'm using an aftermarket skirt.
Old 04-03-2014, 10:18 AM   #14
marcus
toyota
marcus's Avatar
Ok I got the clip was the wrong part # but I still thank weeyari for the help but here's the right part # for this clip atleast Canadian and they are $1 each clips.
Old 04-03-2014, 10:26 AM   #15
I had that part# too and should have given it to you. The one I gave you was for a "retainer", and the other a "clip". I made a judgement call on which one and was wrong . Good price, I had been given $4 each.
OEM Side Skirt Fitment HB/Sedan eablola69 Cosmetic Modifications (Exterior/Interior) 6 03-18-2014 01:00 PM
Side skirt molding ilikerice Cosmetic Modifications (Exterior/Interior) 4 08-09-2011 04:48 AM
Strange tape where the spare tyre is kept mikastefh General Yaris / Vitz Discussion 8 06-15-2010 07:48 AM
Double side tape from visors DandiDani General Yaris / Vitz Discussion 12 10-15-2009 07:49 PM
Rear skirt needed Danish Yaris Cosmetic Modifications (Exterior/Interior) 6 01-09-2009 04:54 PM
