![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
1st Gen ECU Options
Hey guys,
I'm slowly piecing together a turbo setup for my 1st Gen Echo Hatch (JDM Vitz) I've been looking at a few ECU options, namely the AEM FIC & Greddy E-manage Ultimate. Upon reading the description on the MircoImage listing, it says the FIC is for OBD-II vehicles, my car does not have that port. My question is, will it still work on my car? The local tuner in my country uses chipped Honda computers, he normally replaces the Toyota distributors with a Honda variant however my car uses coil-packs so I'm a bit skeptical. He did say he can tune AEM computers. He recently bought an Evolution 6 to work on, he replaced the stock coil-packs with a Honda Distributor and the car is running well. Another question, how to I convert the stock MAF setup to a MAP setup? Thanks
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
Drives: 1nz-fe Join Date: Apr 2014
If you wish to get rid of the MAF that's fine. I think the tuner you have will be better tuning that way considering the way he choses to tune now. MAP is what it looks to be his way of tuning anyways. I'd consider using FuelTech in your case, it will be the easiest way to tune and delete your MAF. Lots of guys in Puerto use it and it's very user friendly. Stay away from AEM FIC and Greddy, both have issues and horrible tech support not to mention their dated. Keep your coil on plug much better than distributor. Do a little digging around on Google for FuelTech and you will find it to be a very good choice. It even comes with a touch screen controller. I think your tuner with his experience will like this. Good luck.
The FuelTech seems to be a great device however it's a bit over budget, my best bet seems to be a Haltech Sprint 500
The F/IC would be fine for your car. It does not actually require the vehicle to be OBDII compliant to use it. The feature of it over a standalone is that if your vehicle is OBDII compliant you will not lose that compliance with the F/IC, whereas you will lose it with most standalones.
Sprint500 is still a great choice. Still much better than an AEMFIC.
| Tags |
| computer, ecu, engine, tuning |
| 2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) | nookandcrannycar | General Yaris / Vitz Discussion | 7 | 02-22-2014 08:16 PM |
| Will these 1st gen Xb coilovers fit my 2005 echo hatch? | Radvr6t | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 02-18-2014 06:21 PM |
| FS: 16gb Nexus 7 1st gen with case | ezhacker1 | Items for Sale by private party | 0 | 12-05-2013 04:17 PM |
| Transmission Oil for Yaris 1st Gen | adigilani | DIY / Maintenance / Service | 3 | 10-23-2011 02:48 PM |
| 8GB 1st gen Itouch | zachryboles | Items for Sale by private party | 3 | 03-31-2010 09:40 AM |
