Old 04-21-2014, 03:24 PM   #1
ddeschen
ddeschen's Avatar
Drives: 08 4dr Hatchback
How do I turn a "check engine" off?
It is ON since I fill the gas tank and did not screw the gas cap correctly. There might be a trick to turn it off but can't find on this site. Help please.
ddeschen is offline   Reply With Quote
Old 04-21-2014, 03:26 PM   #2
To reset it without a diagnostic tool, you can disconnect the battery for a couple of minutes.
Old 04-21-2014, 03:46 PM   #3
ddeschen
ddeschen's Avatar
Thanks, I'll try it in few minutes as soon as it stops raining.
Old 04-21-2014, 04:09 PM   #4
ddeschen
ddeschen's Avatar
Thanks CTScott; done!
Old 04-21-2014, 08:37 PM   #5
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
normally it take 40 warm up cycles or 80 Key cycles to clear a DTCs.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Passenger airbag light on making turn signals and cabin fan not blowing? thatbryanguy General Yaris / Vitz Discussion 17 08-16-2024 10:23 AM
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
Projectors retrofit, black reflectors and dimmed front turn signals my2sense General Yaris / Vitz Discussion 11 06-20-2012 11:39 AM
Are rear red turn signals planned for Yaris as well ? 77W General Yaris / Vitz Discussion 38 02-22-2010 06:41 PM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
