![]() ![]() ![]() Drives: 09 Yaris 3dr HB, BRZ Join Date: Mar 2011
Inside wheel lifts.. anyway to reduce?
Under fairly aggressive cornering the inside front wheel lifts and spins..
Car currently has tokico blues, tein springs and a rear sway bar. What can be done to reduce this happening? Or is it just me going too fast..? |
Form>Function
stiffer suspension
LSD.
Slow down lol
Sent from my XT1032 using Tapatalk |
Yaris beginner
I don't agree with the stiffer suspension...
Inner wheels get off the ground all the time in racing with the "best" (nice and stiff?) suspensions... Actually, I think it's the opposite... your wheels get off the ground more often when your suspension is too stiff... so when you hit a bump your wheel flies off the ground... Anywayzz, I agree with IllusionX... best solution is an LSD, so that you don't lose so much torque in the wheel that stays on the ground. |
Form>Function
very true ^^
a bit of oversteering will also help your inner front wheel to stay on the ground too.. i think.
The only reason is that you are losing your rear end, and you have to counter steer/accelerate to keep yourself on track before the G force lifts your car on aggressive cornering. |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| new wheel? | Nekofelin | DIY / Maintenance / Service | 1 | 08-10-2010 02:37 PM |
| Resistance/rubbing On Wheel During Sharp Turns? | tasha | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 05-11-2010 04:25 PM |
