#19 |
![]() ![]() Drives: 08 Yaris AT, 350Z GT MT Join Date: Feb 2013
Pretty much done with the 80k miles maintenance.
Items replaced so far: Water pump, water pump pulley and belt. Shocks and springs >>> tokicos red in the front, blues in the back with MR springs. PCV valve. 8Qts ATF + Transmission filter. (in two steps, 4qts at a time) Spark plugs. Fusible link, + and - battery connectors. Added: Oil catch filter. Cleaned: Intake Manifold. 1 Valve. |
#20 |
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
The "dirt" is clutch pack material, pretty normal.
A UOA on ATF is pretty meaningless, as there really is no much oil breakdown due to no exhaust blow-by infecting the oil.No pistons scraping cylinder walls, causing metal shavings. The fluid pretty much is used for fluid pressure, and to keep bands, and clutch packs lubed, that's why it can go 100K miles.
Cheapest DD I could find!! |
#21 |
Gasket part number for transmission and oil plug.
#22 |
The oil catch filter does work, less than 1k miles at the time of the pic.
ATF looks clean also, if now the transmission last 50k more miles it wont be wasted time and effort.
#23 |
This may have been previously stated, but I didn't see anywhere in my manual for my 2008 Hatch base model on how to check the transmission fluid level, or anything like that. Would that imply is doesn't need changing according to Toyota?
I guess I would need to look at the required maintenance services intervals and see if it indicates a change is required. |
#24 | |
Only Happy When it Rains
Colin Chapman disciple |
#25 |
Alignment
Did this using: Tamago's guide to ultimate yaris handling.
http://www.yarisworld.com/forums/showthread.php?t=14026 What do you guys n gals think? |
#26 |
![]() ![]() Drives: 2007 2DR Liftback Join Date: Oct 2011
In my distant past I worked in a transmission shop. Changing the fluid and filter were routine maintenance, and most people waited too long. Need/frequency depends on several factors; I can tell by the color and smell of the fluid when it's time for mine.
I just changed my 2007 hatchback's at 54,200 miles, and it was definitely time. Required about 3.5 quarts of Toyota ATF WS. I used a Fram FT1220 filter kit that was less than $14 from RockAuto.com, plus shipping. Looked just like the original. As mentioned, the filter _does_ have filter-media, and is not just a screen. I like the provided drain plug in the pan. That will encourage me to replace a few quarts every year or two, but I likely won't change the filter again for many years. |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| Should I change my brake fluid? | lh59 | DIY / Maintenance / Service | 4 | 06-26-2012 11:48 PM |
| 1st oil change ; At what miles ? | Hershey | DIY / Maintenance / Service | 42 | 02-03-2010 04:46 PM |
| 2008 Yaris AT Fluid change | Rutherfordman | General Yaris / Vitz Discussion | 8 | 07-13-2009 12:45 PM |
| Synthetic Oil | Kaotic Lazagna | DIY / Maintenance / Service | 122 | 09-20-2007 03:40 PM |
