Old 06-17-2014, 11:12 PM   #1
808Yaris07
Drives: 2007 4dr Yaris
squealing noise with AC on..
Okay...so couple of problems here...first off...my wife's Yaris squeals BIGTIME everytime I turn on the AC. It gets louder when I gun the engine and will eventually go away. But lately..now it squeals when the AC is not on...do I need to replace the AC compressor?
Also...the fan that is under the glove box that shoots the AC into the car is starting to die out and we gotta hit it or kick it to get it to blast on. Anyone ever replace that?
I would like to get the squealing fixed first...is it easy to replace the compressor? Or could it be something else?
Thanks guys...
808Yaris07 is offline   Reply With Quote
Old 06-17-2014, 11:26 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Thanks guys...
think ur jumping the gun...with AC on u have additional load i would first have a look at the belt, replace it as need it . The fan is easy to replace ..now does it do that on all speeds etc
PS with belt off make sure all pullies spin free and no glazing left behind
Old 06-18-2014, 12:02 AM   #3
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Recalls.
I had my seat tracks replaced and window switch lubed.
Anything else a new engine gearbox maybe
Old 06-18-2014, 12:36 AM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Like Exiwolfman said, it sounds like your belt might be glazed over.
Replacing belts are much cheaper than replacing compressors. Try that first.
Old 06-18-2014, 08:27 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Your belt either needs to be tightened, or replacement.
And does your blower fan have the filter installed?
If it only works on the "high" setting then all you need is a replacement blower resistor module. It controls the power to the fan to make it work on lower settings.
Old 06-18-2014, 12:47 PM   #6
808Yaris07
thanks guys...I'll try the belt first. The blower works on all settings..but the fan under the glove needs a kick or a SLAP to blow to the setting on the fan control...but it blows on all settings. I'll try to get the belt changed in the next couple of days. Is it a easy change? I've never changed a belt on the Yaris...thanks
Old 06-18-2014, 12:49 PM   #7
Bluevitz-rs
Yeah the belt is VERY easy to change.
Just loosen the bolt on top of the alternator and if you can the bolt on the bottom. Sometimes you can get it move with just the top loose.
Sent from my iPod Touch
squealing noise at start up maui DIY / Maintenance / Service 13 09-22-2016 01:00 PM
Squealing Belt Noise Toyota3000 DIY / Maintenance / Service 3 07-23-2013 03:06 PM
Loud squealing noise? Tlh DIY / Maintenance / Service 4 04-12-2013 05:01 PM
Brakes Squealing! cmkennedy New England 1 10-30-2011 06:08 PM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
