![]() Drives: Yaris 2 Join Date: Jul 2014
Hello everyone,
I am searching for some photos or a scheme of the serpentine belt on a 2009 Yaris 2 1.4 D4D engine WITHOUT AC. I think it's the same on a Yaris 3 D4D but not on the Yaris 1 D4D or Yaris 2 D4D before 2009 (not the same tensioner system)... You can see here under the engine with an AC compressor. I would like to know how the belt is mounted without the AC compressor. ![]() Thanks for your help! Edit : I think that even the latest VVTI owners might help. The Yaris lastest VVTI engine (after 2009?) has the same tensioner pulley system (see picture below)
![]() ![]() ![]() Drives: yaris hatch 07 640K original m Join Date: Mar 2007
its easy...just get short belt and skip the AC pulley...all else is the same... I did it..
Below is the routing diagram with and without the AC.
To run without AC you would use the 90916-02673 belt in place of the 90916-02674 belt. 1ND-TV Belt.jpg
Thanks you all for your help! I was just wondering if there will still be enough contact surface between the belt and the water-pump pulley
![]() I finally replaced my belt with the shorter non-AC one, and it did great Cheers |
A/C amplifier
After removing all A/C components, I removed the A/C amplifier (unit under the dashboard) as I thought it will not be necessary anymore. But I had to put it back because I realized that without it my blower motor speed is unstable. In fact, it speeds down when I touch the gaz pedal, and goes back to original speed when I let go the gaz pedal. I also noticed that when it has speeded down (foot on gaz pedal) and I turn on the headlights, it speeds up to its original speed. All this happens only when I am driving not stopped.
This is weird, since the A/C amplifier is not supposed to control the blower motor speed . Does it have a current regulation role that might explain what happens without it?Has anyone tried removing it or encountered the same issue? PS : Since I plugged the AC amplifier back everything went to normal, so it is not an alternator or battery problem... Last edited by rasyaya; 07-17-2014 at 09:05 AM. |
#6 | |
Do you have the digital climate controls or just the basic knobs? If you have the digital one, the AC ECU does feed the PWM signal to the blower speed control.
I have the manual (basic) climate control knobs...
| Tags |
| belt, d4d, yaris |
