![]() Drives: Yaris Join Date: Jul 2014
Doors Won't Lock
I just got an 07 Yaris hatch and I cannot lock my doors. It didn't come with a key fob and has no central locking switch. When I try to lock from the inside drivers side it just immediately unlocks. When I do this the passenger side also locks and unlocks. When I try to lock it from the outside the same thing happens. Every now and then I can turn the lock really fast a few times and trick it into locking. I cannot lock the hatch at all. Any idea of what could be wrong or a possible fix?
I tried to search, but couldn't find this exact problem. Thanks for any help. |
Sounds like it has an aftermarket set of door actuators and one is not adjusted properly. Pop off the door cards and take a look.
Thanks man. I tried to get the door card off but had some trouble removing the manual window crank and ended up running out of time. Then while out running errands I shut the door on my right hand and messed it up pretty good so It'll probably be a couple weeks before I can get the door cards off to take a look.
I was able to pop the hatch panel off and look at that lock though. There was no aftermarket actuator on it, but it was sticking a lot so I lubed it up now the hatch locks. I'll reply here when I can get into the doors and see what's going on. Thanks again. |
#4 | |
| Shouldn't the doors lock... | imike929 | Third Gen Yaris General Discussion | 24 | 04-29-2014 09:28 PM |
| Radio stays on, doors won't lock | jtown | General Yaris / Vitz Discussion | 7 | 07-16-2012 09:53 PM |
| Yaris Key fob wont lock my doors! | Treeny | DIY / Maintenance / Service | 3 | 03-29-2012 07:27 AM |
| do the doors automatically lock on 08 sedan | CJMOWBRAY | DIY / Maintenance / Service | 1 | 08-12-2010 07:43 PM |
| Lock your doors in Safari Parks.... | SailDesign | General Yaris / Vitz Discussion | 4 | 11-18-2009 12:28 AM |
