For Sale: Blitz Supercharger Kit (and Gauges and AEM F/IC)
This weekend I bought a turbo Mini Cooper Countryman S All4, so my wife is making me revert my supercharged Yaris back to normal, as I am "only allowed one car that causes me to get expensive speeding tickets."
I have had this one on my car for almost three years now, with no issues at all. Between the prior owner and myself it has right about 20k miles on it. It is still on the car, but once sold I will remove it and will photograph and document the process to make installation very easy for the buyer. Price: $2500 shipped in the US. Shipping elsewhere extra. Includes: - Blitz Supercharger - Blitz Fuel Controller - Blitz Supercharger Actuator switch (works in conjunction with the fuel controller to allow you to decide if the S/C is actuated with low, medium or high throttle position or to turn it completely off. - Set of 1ZZ fuel injectors (with set of brand new o-rings). (The Blitz kit is designed to be used with a completely stock Yaris, so if you are using an aftermarket intake the 1ZZ injectors will prevent the car from running lean with the additional airflow from the intake). - New serpentine belt - NGK 2 step cooler spark plugs (used for <1000 miles) Optional parts: -Auto Meter Cobalt Boost Gauge - used, but perfect: $50 Boost Gauge.jpg - Liftback upper glove box cover - drilled in center for boost gauge: $35 (SOLD) -Auto Meter Cobalt Fuel Pressure Gauge (Brand new, with inline Quick disconnect Tee fitting): $110 Fuel Pressure Gauge.jpg -Auto Meter Wideband AFR Gauge and sensor and bung (Brand new): $175 AFR Gauge.jpg -OEM Engine cover (trimmed to perfectly fit with supercharger: $25 Engine cover.jpg AEM F/IC: $200 (SOLD) AEM FIC.jpg AEM F/IC plug n play Yaris ECM Harness: $350 (SOLD) PNP Harness.jpg
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Damnit. I knew it a harness would come along when im absolutely tapped out
Good deals here
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
AEM F/IC and PNP Harness sold.
The Blitz kit is off the car. I figured out some serious time saving things while taking it off that I am going to write up as a DIY. With them the entire installation, including wiring, can be done is less than a day.
Detailed pictures of the kit and the DIY to follow...
2ZR swap. DO IT! Ask how!
Nice! I did mine in about 9 hours with soldered wires to the ECU. Today I replaced the intake manifold gasket in less than an hour. I had forgotten how savage the blitz is on a freshly reset ECU--ZOOM!
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
You wouldn't happen to be able to take 5 payments would you for the supercharger?
I think financing could be an option.
Modded Moderator
Sent first payment!
Guess I'll be joining the boosted ranks soon
Indeed you will!
Supercharger kit, Wide band AFR Gauge and Boost Gauge sold!
Modded Moderator
Got my three packages in full today
^ Bastard
Only Happy When it Rains
congrats to both.
Colin Chapman disciple |
![]() Drives: G35 / Yaris Join Date: Dec 2008
havent been on this site in years. and felt like i wanted boost. how did i miss this? (oh yeah. havent been on here in years)
#14 |
#15 |
I shipped him one of the nice new sets I bought from you.
#16 |
#17 |
Modded Moderator
I still haven't opened the other boxes, just the one with the supercharger. (Still to busy to even attempt an install of this, probably will be a fall project). Thanks for including the gasket! Really can't wait to get this installed. I may attempt it next month when my go fast mechanic friend helps me to the motor swap in the LeBaron (3.0 V6 getting replaced with a 400hp 2.5 turbo).
| Tags |
| blitz, gauges, supercharger |
