Old 08-06-2014, 12:37 PM   #1
Rakin
Drives: Toyota Premio NZT240
O2 sensor readings from torque.
Hello guys. It's my first post here, I've been browsing as a guest for quite a while now looking at the threads related to the 1NZ-FE and this forum has been quite helpful in helping me gain more knowledge about my motor.
Firstly I must confess, I do not own a Yaris but a NZT240 Premio which consists of the same 1NZ-FE powered drive-train as the Yaris 1.5L under a different sedan shell.
Okay so I've dropped in a recon 1NZ a few months back and I've been noticing recently that there is a strong smell of unburnt petrol coming out of the exhaust pipe. O2 Sensor and MAF sensor was the first thing I checked because they control the fuel loop. The O2 sensor in the Manifold had done more than 100K KMs and was completely burnt out and filled with carbon so my mechanic replaced it. Now I could not get a new one at that time (Lack of availability of the lesser common parts here) and had to settle for a recon one. Note car did not throw a CEL.
I noticed the smell was slightly less than before but still could smell it from the driving seat. I connected my OBDII ELM327 Diagnostic adapter and did a graph view of the O2 Sensor at the manifold (It's the only O2 torque would read anyways). I'm attaching the graph below, is it normal for the O2 to jump around like that? Throttle was held down at 2800RPM.
Rakin is offline   Reply With Quote
Old 08-06-2014, 12:42 PM   #2
That looks quite normal for 02 sensor output.
Since you can smell it in the cabin of the vehicle, I would check for exhaust leaks, particularly where the exhaust manifold connects to the exhaust pipe.
Old 08-06-2014, 12:47 PM   #3
Rakin
I see. I'll check for exhaust leaks first thing tomorrow. Oh and I can smell unburnt fuel from the exhaust tip as well.
Thanks.
Old 08-06-2014, 02:15 PM   #4
Thanks.
Have you cleaned the MAF sensor? Also, if the injectors are plugged they could cause the fuel to not properly atomize and therefore not fully burn.
Old 08-06-2014, 03:29 PM   #5
Rakin
I changed out the MAF a month back (The old one died), I too am suspecting the injectors, but in the past when the injectors needed replacing there would be issues with acceleration or the throttle would be laggy none of which are present right now. The car runs fine except for the strong exhaust smell. Do you think I should swap out the injectors?
Old 08-06-2014, 03:39 PM   #6
I would say only to do so if you have an extra set on hand. Also, verify that the new MAF is the correct part number for your car. I have seen autoparts places over here sell people Tundra ones, which look identical, but have a different part number.
Old 08-08-2014, 09:58 AM   #7
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
At least my Yaris has 2 O2 sensors, one pre and one post cat.
Does your car have 2 of them, too?
The 2nd one should be constant at iirc 1, if not, the cat does not work properly (spoiled, totally wrong F/A mixture, cat not heated up)
I drive, therefore I am.
dj92 is offline   Reply With Quote
Old 08-10-2014, 03:42 PM   #8
Rakin
I believe there is one at the manifold and one just before the cat or after the cat (Not sure). Torque only reads from the manifold sensor sadly, I'll trying to poke in a multimeter and check the other sensor.
Old 08-11-2014, 04:44 PM   #9
dj92
Embracing Curves
dj92's Avatar
Have you already consulted the list of available sensors?
Tap a few seconds on the screen to create a new instrument and check how many O2 sensors are in the list.
If there are two sensors, their values should be available via OBD.
Old 08-14-2014, 07:41 PM   #10
Rakin
Only one sensor available via OBD/Torque. I couldn't check the downstream sensor (I'm sure there is one), need to put the car up a lift. I'm getting a new exhuast soon anyways, is running slightly rich until then gonna be too much of an issue? ELM327 doesn't have access to all the sensors I'm led to believe.
Old 08-15-2014, 05:33 AM   #11
I_Love_My_Yaris
Drives: Yaris, D4D, 90 HP
Rakun, how is your fuel consumption ?
I_Love_My_Yaris is offline   Reply With Quote
Old 08-15-2014, 01:30 PM   #12
Rakin
~8 km/l, it's heavier than the Yaris and traffic here is really bad so no comparable data unless you're in this city. :P
Spark plug torque Geoff Peace DIY / Maintenance / Service 11 05-05-2021 03:48 PM
Torque wrench - looking for a particular type Yarflana DIY / Maintenance / Service 10 04-05-2013 01:09 AM
Effect of DC headers on torque curve? Captain Slow Performance Modifications 23 02-10-2013 12:52 PM
Torque wrench on lugs is critical on the Yaris A-Dingo-Ate-My-Baby Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-13-2011 07:33 AM
