Old 08-07-2014, 03:43 PM   #109
Originally Posted by duende_80 View Post
CTScott Hi, I could not answer before as I have been out all day and gone to buy the command of clean, but the joy did not last long.
In my car the rear wiper works perfectly, the two positions, intermittent and continuous, but have been to test the front and the front turn signal does not work and if I give the water sprayer expels water only and do not move the clean, I guess it has something to do with the four wires to a connector that brings greater.
Did you make any wiring modifications on your car? The turn signals and wipers are not wired into the same connector.
Old 08-07-2014, 05:01 PM   #110
duende_80
duende_80's Avatar
Drives: Toyota yaris D4D
Sorry, I wanted to say that intermittent function not working front or the clean sweep clean by spraying with water.
Sorry for the translation since I do through a translator, (spanish --> english).
duende_80 is offline   Reply With Quote
Old 08-07-2014, 05:11 PM   #111
OK. So, the front intermittent and spray do not work, but the front constant slow and fast do work?
Old 08-07-2014, 07:52 PM   #112
duende_80
duende_80's Avatar
If the rest works, it happens exactly the same as toy toronto in this post: http://www.yarisworld.com/forums/sho...6&postcount=60
Old 08-07-2014, 08:08 PM   #113
OK. He was trying to install a stalk the was not compatible with the Yaris.
Old 08-07-2014, 08:28 PM   #114
duende_80
duende_80's Avatar
So I better not me? There would be no solution lattest even have to modify the connector cables and wires and add my idea in the future is to put the rain sensor and light and I already have both knobs with auto function.
Old 08-07-2014, 09:01 PM   #115
The rain sensor could be wired to the original switch. Is the problem you are having with the switch with the auto mode installed in place of the original?
Old 08-08-2014, 04:54 PM   #116
duende_80
duende_80's Avatar
The rain sensor I have not actually purchased and install a universal sensor and i do not know if I would give problems with the installation in command of the clean.
I'm checking the electrical diagrams and yaris car that came the command of the cleanest I buy and not between English and not much is because electronics do not quite understand the schemes.
Old 08-09-2014, 04:45 PM   #117
duende_80
duende_80's Avatar
Hello CTScott, I've been all day checking the pins of the two controls with multimeter and now to put the original remote car I have found that does not work the front sprinklers, nothing comes out of water and do not know what could be doing something noise but only the wipers move.
Old 08-09-2014, 10:53 PM   #118
Check the 15A WSH fuse that is in the fuse panel under the dashboard.
Old 08-10-2014, 04:02 PM   #119
duende_80
duende_80's Avatar
Thanks CTScott today look fuses and after remembering all engineers toyota by putting the fuses where they have unsuccessfully to remove the fuse probe front and now operate sprinklers, not because they would not work yesterday, but now I have a dilemma, as the fuses are removed? is that the hand position and was not able to get any.
Regarding connectors with multimeter I managed to discover that pins have continuity in every position, match all pins with the original remote all less intermittent position front and roulette to vary intermittent but only at position + choices and this last if you do not understand.
Old 10-16-2014, 08:19 PM   #120
beaker
Drives: 07 Yaris 3 door
Did mine today. Got a switch off ebay for $35.00. Took about 10 minutes. Can't wait till it rains now LOL.
beaker is offline   Reply With Quote
Old 11-02-2015, 05:45 PM   #121
xavi_3d
vrumm vrumm xD
xavi_3d's Avatar
Drives: Toyota Yaris S 1.4 D-4D
Hello, can please anyone tell if this one will work?? It's from a 2010 avensis
xavi_3d is offline   Reply With Quote
Old 11-02-2015, 08:06 PM   #122
No.
Old 11-02-2015, 11:07 PM   #123
bairjo
No.
Scott, do you think you could in the future shorten your response a little?
Old 11-03-2015, 07:55 AM   #124
xavi_3d
vrumm vrumm xD
xavi_3d's Avatar
No.
Thank you.
Old 01-13-2016, 04:17 AM   #125
lambros
lambros's Avatar
Drives: TOYOTA YARIS S 2009
https://www.youtube.com/watch?v=rrnPQZc0AMw
Rav4 07 stalk and all functions works front and rear wiper
Euro speck liftback 09...
lambros is offline   Reply With Quote
Old 01-13-2016, 07:50 PM   #126
Frank the Tank
Drives: 2007 Toyota Yaris
More info needed.
Also what year rav4
Frank the Tank is offline   Reply With Quote
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
variable intermittent wipers thebarber Cosmetic Modifications (Exterior/Interior) 27 10-18-2022 04:26 PM
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 08:22 PM
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 11:39 AM
Making Intermittent Rear Wipers ttufrosty Cosmetic Modifications (Exterior/Interior) 1 08-12-2007 11:57 PM
