Old 08-07-2014, 12:35 AM   #1
MoneyT8
Drives: White Yaris Sedan
What car battery do you use?
My car battery is dying and was looking for a replacement, any recommendations? My current battery is a Duralast which was bought nearly 3 years ago. How does the car battery warranty work? Thanks.
MoneyT8 is offline   Reply With Quote
Old 08-07-2014, 01:11 AM   #2
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
I use Costco. When it fails, i just go back to Costco and exchange/return for a new one. Best value for one time buying a battery that will "last" forever.
Check out my Build thread:
Old 08-07-2014, 05:55 AM   #3
bronsin
bronsin's Avatar
I buy the cheapest thing out there and they generally last more than seven years. Even my motorcycle batteries. I guess I live where its not to hot or cold and I drive every day the same 6 miles.
Incidently I was in Pep Boys the other day and the cheapest battery was $115 and there were some over $200!
Old 08-07-2014, 06:56 AM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
Dépends where you live for a battery to last. Hotter the weather, less longer it will last is a rule of thumb.
I always tend to use the cheapest battery out there.. But I'm still on my original Panasonic battery from 2006...
Old 08-07-2014, 01:08 PM   #5
wufai
Drives: Silver Yaris Sedan (4A)
I just purchased a Exide Edge AGM battery for my Yaris, I was using the orginal battery since 2007 and last winter it failed me twice on starting up.
I got the Exide Edge for $135CAD, where a generic battery is selling for $99. I figured the extra $36 for another 4 years is a good investment. I plan on adding a subwoofer to my Yaris and the additional battery I used for charging 2 ipads I figure a better battery will last longer.
wufai is offline   Reply With Quote
Old 08-07-2014, 01:10 PM   #6
The Limo 2
Just changed my battery. Went to Costco and paid $110.(plus tax and enviro fee) Three year replacement then prorated for a total of 100 months.
Roy
The Limo 2 is offline   Reply With Quote
Old 08-07-2014, 10:13 PM   #7
bail_w
Drives: 2007 Toyota Yaris LB
I went with Costco battery as well.
bail_w is offline   Reply With Quote
Old 08-07-2014, 10:26 PM   #8
I am a big fan of the Napa Legend battery. The 7535 model is a perfect fit.
Old 08-09-2014, 02:58 PM   #9
07stlYaris
If Its Not Blown It Sucks
07stlYaris's Avatar
Drives: 07 Yaris LB Meteorite
Optima Group 35 yellowtop for me. I figured I had one in my Vanagon for 11 years before it finally crapped so I can hope for 5-7 with this one.
07stlYaris is offline   Reply With Quote
Old 08-09-2014, 03:13 PM   #10
IllusionX
It really depends where you live. AZ heat will probably kill the optima with 3-4 years still whole it would last 10 years in NY.
I usually tend to buy the cheapest one at Canadian Tire store... I'll see what I will do with my Yaris as it is still running on its original battery from 2006.
Old 08-09-2014, 04:22 PM   #11
MoneyT8
So I decided to go with the Costco Battery and when I went in today to buy one the clerk told me it was not available for the 2007 Yaris? I find that hard to believe since the Yaris is a economical car. So I was wondering how did you get one for your Yaris at Costco? Do you have the model number? Thanks
PS I'll probably go with Walmart EverStart.
***Update just got back from Walmart and there batteries are not compatible either; what gives? I'll try DieHard or my Duralast and be done with it.
Old 08-09-2014, 04:58 PM   #12
IllusionX
Ask them to check for other yaris years. They are the same.
Even the Toyota echo have the same battery. Group 35 it is.
Old 08-09-2014, 07:36 PM   #13
Same size yes, but terminals reversed.
When mine died while on vacation last year in Moncton NB., I was forced to buy the only thing available on a Sunday out there. For $87 plus tax, I bought a store branded battery from The Battery House, a local outfit. I have no idea what the hell it really is, but it has more CCA and greater reserve than my OEM. Carries same warranty as the best of them so time will tell. So far so good, but it is only a year old.
Old 08-12-2014, 10:54 AM   #14
Vinceb
Drives: 2008 5 Speed Sedan
I've still got the original Toyota battery in mine, I've accidentally killed it twice, charged it back up and still going. Canadian Tire told me it needed to be replaced the second time I killed it and that was 2 years ago.
266,000km on an 08 sedan
Vinceb is offline   Reply With Quote
Old 08-14-2014, 05:41 PM   #15
clarenceie
Drives: Yaris Sedan
Just replaced mine a couple day ago with Costco battery. Group Size 35. Great performance rating! Should be more than enough to start the yaris right up.
clarenceie is offline   Reply With Quote
Old 08-14-2014, 07:43 PM   #16
Astroman
Modded Moderator
Astroman's Avatar
I use a Walmart Everstart. Works just fine. Picked it up after my original battery died in a Walmart parking lot.
Old 08-14-2014, 09:43 PM   #17
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
still on my original 07 ....will see how it does this winter .
Old 08-14-2014, 09:47 PM   #18
alanwagen
soon
The battery is like 6 years old and starting to swell a little. Going to replace it next month when it cools a little. Going with the Napa, it has good stats.
I would rather be proactive and NOT get stranded.
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
CtrlAltDefeat - Photo-Scavenger Hunt CtrlAltDefeat Photo-Video-Media Gallery 0 03-04-2009 02:14 AM
Custom Lftback - Photo-Scavenger Hunt custom Lftback Photo-Video-Media Gallery 2 03-01-2009 11:12 PM
