Bolt Thread Size 4 Brake Drum Removal
Does anyone know the bolt size need to back off the rear brake drums. Hafta check 'em for inspection and they aren't budging with hammering.
10mm x 1.5
![]() Drives: 08 Yaris HB Join Date: Oct 2008
I use one of the bolts from the hood support.
thanks, hafta try the hood support bolt.
![]() Drives: 07 yaris rs Join Date: Jun 2011
if you have access to an air chisel try that with the bit I use for pushing bolts through leaf spring ends. go around the hub until it changes sound and it should come off
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
BtY,
please keep us posted. I may need to do drum service too. Are you replacing anything, or just cleaning, adjusting, and bearing repacking? |
| Shift lever thread size | Chaad32 | Cosmetic Modifications (Exterior/Interior) | 16 | 01-30-2015 02:16 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| Shifter thread size | kargoboy | Cosmetic Modifications (Exterior/Interior) | 7 | 12-18-2008 11:06 AM |
| Transmission Drian Bolt washer size | CB900F2 | DIY / Maintenance / Service | 14 | 12-07-2008 07:03 AM |
| Exhaust Pipe Size (Tamaņo del tubo de escape) | carlosh | Central and South America | 11 | 08-02-2007 04:15 PM |
