Old 08-17-2014, 05:23 PM   #217
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Sorry, man... there are no more tooter aluminum intake manifolds available. Check with "Malibu" on this forum. He had one that might still be for sale.
Greg
Old 10-21-2014, 09:37 AM   #218
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Cool
That article link was a good read.
I definitely want coil overs and a roll bar now.
Workin on switchin to 16 inch rims with Michelin Pilot Sport AS 3's next.
My favorite rim choice at the moment is the 4 bolt Helium or Feather black.
Thanks for the good article link/read Cali
Old 10-21-2014, 09:40 AM   #219
JimKellyfan
Originally Posted by crazylegs View Post
my little ApeTurd
hahahahahaha
LMFFAO
Old 02-22-2015, 09:28 PM   #220
mario98c
mario98c's Avatar
118whp Dynojet
Mods:
Custom intake with velocity stack (no air filter)
2" exhaust catless with stock resonator and DC Sports muffler
NST 10% Underdrive Pulley
DC Sports Header
Intake Manifold thermal gasket
Knock sensor relocated
91 oct gasoline
Old 03-23-2015, 03:32 AM   #221
Barneyncp93
Drives: Vios NCP 93
[img=http://s15.postimg.org/5j63njymf/vios_camcon_freeflow_colletor_no_hasta_on_it.jpg]
NCP93, manual, with free flow collector & camcon. Camcon was only used to adjust the cam timing. No AFR changes were made. Header, air filter, and etc, were standard.
Barneyncp93 is offline   Reply With Quote
Old 03-25-2015, 09:27 AM   #222
scod4025
Drives: 12 LE 5d HB 1nz-fe Automatic
Ok so need to get on this thread as well
103.4 WHP
this is with the automatic
scod4025 is offline   Reply With Quote
Old 05-16-2015, 11:02 PM   #223
tooter
play every day
tooter's Avatar
What kind of chart is that?
Makes my eyes cross.
Greg
Old 05-17-2015, 12:13 PM   #224
scod4025
I cant say its what they gave me but don't think it was a very good pull as I drive an auto and every time he would floor it it would down shift to second then sift back up to 3rd half way through the pull but what ever I am on the board
Old 05-17-2015, 12:22 PM   #225
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Weird
Old 10-09-2015, 10:22 AM   #226
AzianCuz
conundrum562
AzianCuz's Avatar
Drives: Toyota Yaris 2007 Type S
Send a message via AIM to AzianCuz
Question
So I messed around and did a Dyno but it wasn't "DynoJet" the guys at MotoIQ says that the DynoJet would have about 30HP over their Dyno. Anyways I got it done with the Blitz S/C on off which gave me 66 on their dyno which would be about 96 on the dynojet and then they tested with the Blitz S/C on which is the picture I posted. Not sure what any of it means though...
BLITZ S/C|MICRO-IMAGE CRANK PULLEY|NST ALT;WATER PUMP PULLEY|BLITZ SUS SHORT RAM;HEADERS;AXLE-BACK EXHAUST|2.25 PIPING|1ZZ INJECTORS|OPTIMA YELLOW-TOP|GTSPEC FRONT STRUT;MID LOWER CHASSIS;4 PNT FRNT LOWER BRACE|WHITELINE REAR SWAY;BUSHINGS|TANABE FRNT SWAY|TRD LOWERING SPRINGS/SHOCKS|R1 CONCEPT DRILLED & SLOTTED ROTORS|EBC GREEN PADS|THROTTLE SPACER|XTREME PERFORMANCE CHIP MOD
AzianCuz is offline   Reply With Quote
Old 10-11-2015, 11:58 PM   #227
fnkngrv
fnkngrv's Avatar
Can't really read it?
Sent from my SCH-I545 using Tapatalk
Old 01-21-2016, 12:48 PM   #228
fnkngrv
fnkngrv's Avatar
Made 315whp and 219tq on a Mustang Dyno.
Would be roughly 350/240 on a DynoJet.
Sent from m-o-b-i-l-e
Old 01-21-2016, 03:17 PM   #229
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Wow look at those RPMs!!
What does the torque curve look like if it peaks at 7300?
Old 01-21-2016, 04:34 PM   #230
fnkngrv
fnkngrv's Avatar
Still building power at even 8k. The plan once we clean up a few issues is to go back down again, turn up the boost, and set the limit at 8500.
Old 01-21-2016, 05:15 PM   #231
Bluevitz-rs
Torque is the blue line right...
Not too bad. Pretty flat for how high it peaks.
Old 01-21-2016, 05:55 PM   #232
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Geez louise, 350 bhp.
No joke.
Old 01-21-2016, 09:09 PM   #233
tmontague
tmontague's Avatar
You almost hit numbers as high as I do on my Yaris
All jokes aside, that's an awesome power curve
Old 01-21-2016, 09:19 PM   #234
fnkngrv
fnkngrv's Avatar
Yeah, torque is blue.
WR Yaris Intake Picture & Dyno. WRLEO Performance Modifications 37 04-05-2007 07:02 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
