![]() Drives: Toyota Yaris 2006 Sedan Join Date: Aug 2014
Small crack found in engine. Concern ?
2006 Sedan.
Sorry for the newbie question but I was wondering if this crack (which is quite small) is of a concern? Is it just a plastic covering ? Just FYI, the 'stop and check engine light' doesn't appear when I'm driving nor do any other dashboard indicators. Also haven't noticed any differences in driving the car as of yet. Pics: 1) http://i.imgur.com/fAWF9Or.jpg 2) http://i.imgur.com/VKGYQXS.jpg thanks in advance! |
Only Happy When it Rains
What he said, if that is an actual hole instead of a surface scratch, fix it soon.
Colin Chapman disciple |
start car , light smoke and blow smoke over hole and see if it actually is a hole or just a small imperfection ...kind off like a smoke machine when looking for vacuum leaks ..if smoke goes in u have a leak if so fix it :P
Mr. 155 and climbing
you can pick up a used intake manifold for like 50 bucks which is much cheaper than what could happen.
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. Last edited by fnkngrv; 08-23-2014 at 07:47 PM. |
That's the intake manifold not the engine block. Which is plastic...engine block metal.
If it were a hole I would have to believe the engine would not be running normally and the check engine light would be on. But blowing smoke at the hole from a cigarette and seeing it sucked into the engine would prove me wrong! Also, spraying a can of starting fluid at the hole and hearing the engine speed up would confirm its a hole.
When I bought one of my wrecked ones the alternator had been pushed into the intake manifold and it took a chunk out of that runner. The car ran slightly rough, but I was amazed that even sucking in that extra air that it did not through a code. I suspect that it would have thrown a lean code on that cylinder if I pushed it.
That being said, the O.P. should definitely patch the hole or replace the manifold. I patched mine with black silicone and it has been running fine on Crashy for quite some time.
Since the manifold is plastic epoxy will do it. No need to replace it.
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
Quick way to check for a air leak is to spray WD40.
If the idle increases you have a leak. Steve |
2x
![]() ![]() Drives: Yaris 1F8 Join Date: May 2013
A little high heat permatex in black can also seal the crack..
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
| TC swap? | MicroHB | Performance Modifications | 38 | 03-26-2009 12:39 AM |
| Need help badly looking for engine swap places in gta | Adriaan | Canada | 7 | 02-23-2009 08:14 PM |
| Info regarding Engine change. | sheraz2000 | General Yaris / Vitz Discussion | 5 | 01-08-2009 12:51 AM |
