Old 05-27-2014, 11:55 PM   #37
end user
GRO H2O
Drives: Yaris
Originally Posted by CrankyOldMan View Post
The white ones don't look any larger--it's all about the size of the tires on them. Putting a 1.75-2" drop on makes them look even sillier.
I would't go that big of a drop as I do haul around quite a bit with the car. I'd probably just drop max 1.5 or less if I had the springs custom made.
end user is offline   Reply With Quote
Old 05-28-2014, 07:06 PM   #38
end user
GRO H2O
Drives: Yaris
Here's a 2 min lowering job with about 300-400lb of extra weight
Old 08-25-2014, 07:26 PM   #39
jayman
Drives: Yaris Sedan
Stock lug nuts work, but I would not want to run them for very long. Mini lugbolts (shown below) are 14mm (versus our 12 mm lugs), so there is quite a bit of slop to the holes, which results in a significant portion of our OEM lugnut taper sitting in the hole.
Attachment 53483
The lugnuts which I referred to in the link in post #2 above are shown below. They have a much larger tapered section than our stock lugnuts and the "bulge" fills the 14mm to 12mm gap. They were difficult to find since, as mentioned above, most conical bulge lugnuts are not metric.
Hey How long did it take you to get these lug nuts it is showing online that they want even ship until 9-6-14 ?
jayman is offline   Reply With Quote
Old 08-25-2014, 07:30 PM   #40
jayman
Drives: Yaris Sedan
How long did it take to get these lugn
ut online it is showing me they will not ship until 9-6-14
Question about these rims. Bar_Red_Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-09-2011 08:54 PM
My 17" alloy rims and Kumho tires... will swap for your original wheels! AutoWashCars NY / NJ/ CT / PA 5 02-08-2011 07:38 PM
RIMS a Noob-toob question =] donchae Wheels, Tires and Suspension Forum sponsored by The Tire Rack 45 10-17-2010 06:11 PM
Question about Rims MrJester Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 03-06-2007 10:16 PM
hufeisen rims JustYYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-17-2007 03:16 PM
