![]() ![]() ![]() Drives: 2003 Mach 1 Join Date: Oct 2008
Took 10 minutes max and works like a charm!
2ZR swap. DO IT! Ask how!
Did you have the odometer matched? I swapped mine out but didn't bother since MI only requires you to note the existence of the discrepancy, not the difference.
I matched the odo for him.
Man! How do I get one of these?
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
Forgive my ignorance, but how is the "Yaris S gauge cluster" different from the base gauge cluster? Tachometer?
ctscott is the bomb! i had him switch the leds to blue and match the odo reading, love my cluster.
For the US market, prior to 2010 only "S" Yaris had the tach.
Wow I haven't seen a S cluster in a long time, you , I and few others have these and not the Canadian ones.
Now I'm still hoping for a digital LHD one
Big thanks to CTscott for programming the correct mileage and shipping it down here for me! I know it's more less just a cosmetic mod but I missed not having a tach and didn't want to do a non-matching aftermarket piece. Install was really a piece of cake!
Seriously, how'd you get it? I would love to get one. Thanks!
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
I forgot, is there such a thing as instrument cluster for a manual Yaris 2, with tach?
I had picked that one up from a local junkyard quite a while ago. The S ones are very hard to find, as there are not many of them around, let alone wrecked.
I can also convert Canadian ones to have he odometer increment in miles and have the outer ring of the speedometer indicate mph, rather than km/h. The Canadian ones are way easier to find, as tachs were not just for S models up there.
Yeah its pretty rare to see any S yaris. Came down to luck for me to snatch it off of the forums.
Only 2010+ for the US.
![]() ![]() Drives: 07 Yaris 3 door Join Date: Feb 2013
I have an 07 Yaris hatchback, auto trans, non abs.
If I wanted to do this upgrade, what cluster do I need to look for? Anyone have a part # or which model yaris to look for to get a cluster out of? Will a sedan cluster work in my hatchback? Thanks Last edited by beaker; 09-20-2014 at 07:52 AM. |
#16 | |
For non direct solutions, you can use an 09-11 cluster, but all 09+ have ABS, so the ABS and BRAKE lights would have to be disabled or they would always be on. For 2010-2011 the TRAC light would also have to be disabled.
#17 | |
Which of the clusters you have listed above also have the cruise and foglight indicators that I could also utilize when I add these options to my car? |
| Yaris 2 D4D 2009 without AC serpentine belt | rasyaya | DIY / Maintenance / Service | 6 | 07-17-2014 09:02 AM |
| 2009 Yaris and wind sailing | GrayYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 10-26-2013 07:52 PM |
| how do I install a different headunit in 2006 yaris? | wouterw | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 05-13-2013 07:55 AM |
