Old 09-19-2014, 05:20 PM   #1
Strat
Drives: 2008 Yaris 4-door hatchback
Suggestions for wipers on 2008 Yaris.
Hey guys. 1st-time poster, here! :D
It's a bit disheartening shopping for wiper blades because it seems that no matter which ones we pick, we always end up with major streaking.
Do you guys have any suggestions as to which ones I should go for next?
So far, I have tried the MotorMaster (Canadian Tire), Tric Force, OEM, and close to pretty much anything Canadian Tire has available.
I'm thinking of the Trico NeoForm which are *not* available at CT but I'm tired of the streaks which are so bad that it's making driving in the rain extra challenging, right now.
If it's something that's available in Canada, that'd be fantastic!
Looking forward to your replies! :)
Strat is offline   Reply With Quote
Old 09-19-2014, 05:48 PM   #2
Nothing wrong with oem inserts. Available from Toyota parts department and cheap.
Of course that is only an option if you still have your oem blades kicking around. You can also try treating your window with RainX. I don't understand why you have such an issue with streaking. We've all used a variety of replacement options, and no one complains of consistent streaking issues across all brands.
Old 09-19-2014, 06:36 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
I haven't had issues. My glass is always treated with rainx but mind you, I do get streaks when using the fluid to clean the glass. But it is never an issue with rain.
Old 09-19-2014, 08:07 PM   #4
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I use the ones from Canadian Tire that cost about $10 each. havent had any streaking issues with them.
Have Yaris will travel..
Old 09-22-2014, 11:35 PM   #5
JustPassinThru
Drives: No more Yaris
Bosch Icon beam blades.
I've used them in four cars, over the last couple years, worked fine in all of them in all weather.
I find that going a little shorter than OEM length on the driver's side actually gets you better wiper action - less tendency for the blade to lift at highway speeds. You may not be able to buy a Bosch blade the same length; but a couple inches shorter will probably work okay without a gap where the passenger-side wiper path comes up against it.
JustPassinThru is offline   Reply With Quote
Old 09-23-2014, 01:19 AM   #6
fourbangingfun
fourbangingfun's Avatar
When I went to advanced auto parts I could only find a "uni" style blade that would fit the drivers side. A year later it's running well and streak free. The passenger side's blade is so short I had to buy a traditional multi pressure point blade for it. It works fine just doesn't look as clean as the uni style in my opinion.
fourbangingfun is offline   Reply With Quote
Old 09-23-2014, 01:48 AM   #7
IllusionX
I've never had issues with the driver's side 26" blade. It never lifted at hwy speed.
As for the passenger side, they are mostly available in 14" for the hatch. But the sedan's 13" is a bit harder to find.
I did find them in both walmart's viewmax brand and Canadian tires' reflex brand.
I also notice that such small wipers are hard to find in the states, especially the frameless ones.
Old 09-23-2014, 06:57 AM   #8
bronsin
bronsin's Avatar
Streaks result from dirt on the wiper blade or windshield. Scrub the blades with a stiff brush soaked in alcohol or windshield washer fluid. Feel the windshield for embedded debris and scrub that off too if you find any.
Try parking the blades vertical instead of horizontal.
Old 09-25-2014, 12:16 AM   #9
JustPassinThru
Frameless states?
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 09:08 PM
2008 PeterPoop's Turbo Yaris 5 speed Base model. PETERPOOP Cars for Sale by private party 32 07-18-2011 04:34 AM
Difference between 2007 and 2008 Yaris? wihed General Yaris / Vitz Discussion 5 01-02-2011 09:20 PM
