Old 09-26-2014, 01:15 AM   #1
Axiot
Drives: Yaris Hatchback 2010
K & N Intake Trouble
Hello everyone, I recently installed a typhoon k & n intake on my Toyota Yaris hatchback 2010. The engine works fine but sometimes and repeatedly when I am in a stop the engine starts vibrating very rough until it reaches q peak and stops vibrating, it vibrates the whole car. I have tried tightening all the hoses but that doesn't seem to fix the problem. Any ideas on what it might be? Thank you in advanced.
Axiot is offline   Reply With Quote
Old 09-26-2014, 01:52 AM   #2
Jlively
Mr J.
Drives: 2009 yaris 5 dr HB
Send a message via AIM to Jlively
Might have the IAT sensor slightly misaligned on the intake tube?
Jlively is offline   Reply With Quote
Old 09-26-2014, 06:30 AM   #3
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Check the maf make sure its properly seated and clean too
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 09-26-2014, 07:45 AM   #4
How recent was recently?
If you had the battery disconnected while installing the intake, then the ECU is in learn mode and the car will idle very rough, nearly stalling out, until the air/fuel mixture is reset. This process takes some time.
Old 09-26-2014, 08:48 AM   #5
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
Yeah mine did that too - you have to disconnect the battery's negative terminal. It should run perfect after that;)
firebird1999us is offline   Reply With Quote
Old 10-03-2014, 02:48 PM   #6
Foot
Drives: 2010 3dr yaris
Mine does something similar every since I got the car. The rpms fall to around 500 and will kick back up to 800 and idle there. At some point at the traffic light it may fall to 500 rpm again and do the same thing. It has never caused problems just something I notice from time to time. I have a 2010 manual and a cone KN filter.
Foot is offline   Reply With Quote
Old 10-03-2014, 03:31 PM   #7
Axiot
Thanks guys, the problem has ceased to exist. It was the ECU was just adapting. Thanks.
Old 10-13-2014, 08:07 AM   #8
farhan_far
Drives: Toyota yaris 2012
K&N intake fittment
hello
i want to know if K&N 69-8612TFK will be fit in my new toyota yaris RS 2012 1nzfe engine?
farhan_far is offline   Reply With Quote
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
The great intake debate! fmicle General Yaris / Vitz Discussion 74 10-06-2009 11:37 PM
