Old 09-26-2014, 06:32 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
remove door handle
07 hatch manual trans and manual windows
how do you get the door handles off so you can remove the door panels????
also how do you repair all the busted clips that happen when you start pulling on the panels??
yaris9876 is offline   Reply With Quote
Old 09-26-2014, 06:46 PM   #2
To remove the window crank, place a thin rag between the handle and the thin clear plastic disc. Then slowly work the rag around until you feel it snag on the retaining clip. Once snagged, gently tug and work the rag until you see the clip start to pop out.
Are you saying you've already busted some clips, or just anticipating that you will bust some?
Old 09-26-2014, 08:43 PM   #3
yaris9876
I see
I have already broken a couple
I make sure to put vaseline on the pins when I push them in again... that helps.
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 11:05 AM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Car shuts off when A/C turned on... Howster DIY / Maintenance / Service 33 07-06-2013 05:00 PM
