![]() Drives: yaris Join Date: Oct 2014
Hiya sorry my first post is needing help I had no were else to turn too..
The other day silly me thought it be a good idea to open a tin of paint with my keys next think it snapped in half so I rushed out got another one cut and the chip programmed it opens the door but failed to start the car.. Any idea or help it a yaris 1.3 Cheers |
Some more experienced members can chime in later, but i can make a suggestion.
You can still start your car with your old broken key next to the ignition when you start it. At the very least you can still drive it till you get it all sorted out. Though im not sure if the car will turn itself off if the chip is removed from proximity to the keyhole after you start the car. I just tested it to see what would happen and it either stayed on or turned itself off. You could tape the broken key head next to the key cylinder.
It should work with just holding the head of the broken key next to the ignition switch. Once started the car will not shut off if the transponder key is not seen (it is only interrogated for starting).
It does sound though, like whoever programmed the key, did not make the ECM learn the new key. The original key will have to be present to do so.
Thanks for the quick reply I've done the tapping my old key to the transponder it still fails to start also
Also got another transponder today from the scrap yard with matching key I fitted that still the car won't start so i don't understand so lost cars parked at work need to get it moved soon :( I've got 3 keys 1.new key with chip programmed q 2.spare key cut to the car without chip 3.new transponder with key and chip 4.old broken key head |
The car should start normally, with even the broken key head next to the ignition key.
It weird it fails to start then:(
So including having another transponder and key fitted it should still start? Or am I missing something else.... orgot to say in my last post is there away to program the ECM? Cheers |
Anyone able to tell me were the immobiliser/ecm is I've looked under the dash couldn't see it :)
#8 | |
![]() Drives: Silver Yaris Sedan (4A) Join Date: Jul 2007
I hope you didn't damage the transponder chip when opening that tin can...
