Old 10-05-2014, 07:54 PM   #1
ex-x-fire
hotter thermostat for more mpg
Has anyone installed a hotter thermostat for increased mpg? I had a scanner on my 2010 yaris for the 1st time, I noticed the temp never got hotter then 185. It make sense b/c it has a 184 stat in it & it was cool out that day (low 50s).
I've had some experience on GMs with hotter t stats & improved mpg. It usually adds a couple highway mpgs esp. on colder days. The TDI guys have had great luck with them.
Old 10-06-2014, 05:52 AM   #2
bronsin
bronsin's Avatar
I tried a block heater and it didnt improve mpg enough to make it worth the $$ and trouble.
I doubt very much you would notice the increased mpg (if any) from a hotter thermostat. And I can think of problems like over heating the engine in stop and go traffic in summer or burning out the fan sooner or something similiar.
Old 10-06-2014, 07:17 AM   #3
ex-x-fire
Why wouldn't I see an improvement? Esp. if the engine is running right at the t stats rating, the fan shouldn't kick on till 205. The coolant temp sensor that tells the computer the temp has a huge impact on fueling the engine.
I had a gm truck that I ran a 180, 195, & 205 stats. I lost mileage with the 180 (-2-3mpg) & gained some with the 205 stat over the stock 195.
Old 10-06-2014, 07:33 AM   #4
woops
Drives: Jeep Cherokee XJ 1996
If you live in a cold area that makes sense otherwise just kill this thought of yours :p
woops is offline   Reply With Quote
Old 10-06-2014, 02:08 PM   #5
bronsin
bronsin's Avatar
I guess I really dont know if it would make much of a difference. My gut just tells me it wouldnt and that it could cause problems you would rather not have.
But I might be wrong.
Try it and see. You can always go back to regular.
Old 10-06-2014, 02:41 PM   #6
You've touted personal and known experiences with other manufacturers. T-stats are cheap enough to experiment. Do it, be the first here and blaze a trail.
Old 10-06-2014, 07:53 PM   #7
ex-x-fire
Yeah, I've been looking at different ones. The yaris takes one with a 56 mm base, I'm having trouble finding a hotter rated one. I might have to combine 2 to make one.
Old 10-07-2014, 07:29 PM   #8
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Or you could block off some of the front vents and get the same effect with a little better aerodynamics to boot.
Colin Chapman disciple
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 08:38 PM
Why sub-compacts and compacts get almost the same MPG Kal-El Off-topic / Other Cars / Everything else Discussions 0 08-10-2011 11:51 PM
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 12:15 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 11:49 AM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
