![]() Drives: 2014 Yaris LE Join Date: Oct 2014
Glove box damper... where does it connect?
Hi everyone,
Only been driving my new Yaris a couple of weeks. I have the bluetooth hooked up but when my GF is in the car she used the AUX because I like to have my hands-free "free" in case someone calls and I want to answer without touching my phone. This means my glove box is opened and closed almost every day. Today my "damper" disconnected from inside my glove box... not from the end that attaches to the glove box door, but where it affixes to inside the dash. I see that the end that attaches to the door is disconnected when you have to remove the glove box in most cases. I must be crazy because I cannot figure out how to reconnect this damper. It seems like even when it's closed it is too long to connect to the notch I see inside the dash. Has anyone else had issues with the damper and could tell me where each end is supposed to connect? Should I just leave it disconnected? I feel incredibly dumb asking because this seems like an easy fix but I am stumped. Thanks in advance for any help! |
I am not sure that I completely understand your issue, but I believe that you are saying that the control that adjusts fresh versus recirculated air has popped off on the control knob side.
If that is the case, the key is to make sure that both are in the same potion when reconnecting (i.e. if the knob is in recirculate mode, then the damper should be open when reconnecting the cable to the knob.
![]() ![]() Drives: 2014 Icon+ 1.33l Multidrive Join Date: Nov 2010
I think they mean the damping rod which is attached to the glovebox lid one end and the car at the other. The glovebox end has to be pulled off to allow the lid to drop for access to the cabin filter. This rod has disconnected from the car end.
I could well be totally wrong though.
#4 | |
This is the best image that the service manual shows as to how the "glove box stopper" mounts: Glove box damper.jpg
Man, you guys are good. I had a feeling that I was going to feel a little dumb once someone pointed out the correct assembly to me... but it's even worse than I anticipated, haha. Apparently my problem solving skills are slim to none.
Thanks a lot for the help, guys. Much appreciated. Not sure how many threads you check, but wanted to echo what I put on the welcome thread. When my old car was dying, I started looking at new cars for the first time. Always like the Yaris but was getting pushed in other directions... found this site and the rest is history. This site was great and reading all the good opinions (and even some bad) made me realize this was my car. Loving the thing so far. Cheers for moderating a great site and for helping out all the noobs like me! Hopefully one day I'll be lending tips on here. Thanks again. |
As an aside, I'm hoping that having the usb and aux ports in the glove box won't cause the glove box to fall apart after awhile. If it weren't for the hands free calling, I'd get my girlfriend to just use bluetooth to play music. Might have to get creative on this one.
| Dual 8’’ Cargo Floor Sub Box Build | Ataristyle | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 03-23-2016 01:27 AM |
| Advantage Drivers Side Glove Box! | bronsin | General Yaris / Vitz Discussion | 15 | 02-18-2014 12:42 PM |
| Sub Box Desgin | talnlnky | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 08-23-2009 01:45 AM |
| Rubber plugs in glove box | cfiimei | DIY / Maintenance / Service | 5 | 01-06-2009 04:48 AM |
| FS: Glove Box Damper (GTA) | Teruyume | Items for Sale by private party | 1 | 07-02-2007 01:58 AM |
