Old 11-02-2014, 01:51 AM   #1
xmanf14
Drives: 2013 Yaris
Engine rev limiter override
Hello:
I have a 2013 Yaris with a manual transmission. California emissions. Does anyone have any experience in attempting or successfully bypassing the rev limiter on this vehicle?
xmanf14 is offline   Reply With Quote
Old 11-02-2014, 10:15 PM   #2
The Yaris ECM has a hard coded rev limit. To bypass it requires running a stand-alone ECM.
Old 11-03-2014, 09:42 AM   #3
mitchell12
mitchell12's Avatar
Drives: 2007 yaris HB
In some older yotas you could change out the crystal on the ecu. However I am fairly certain any attempt at a similar mod on these ECUs would be difficult and if possible probably mess something else up too since I always thought it chanfe the clock speed of the ECU... might not be the right term.
mitchell12 is offline   Reply With Quote
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 02:01 AM
1kr-fe engine wiring boothybunch DIY / Maintenance / Service 0 03-28-2011 04:59 AM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-13-2010 12:47 AM
rev limiter mastaofdisasta Performance Modifications 2 11-24-2008 04:10 PM
