Horn Button Replacement
How could I tap into my horn button wires to add/replace my broken horn button to my dash. Gonna check into wether it'd pass inspection here.
Sent from my iPod touch using Tapatalk |
The horn switch wire is the one lone black wire on the white connector that goes into the clock spring at the base of the steering wheel. Ground that wire to make it honk. Before you do so though, check the tiny green wire that goes to the horn itself, as I have seen more damaged ones of them than problems with the horn switch itself. The horn switch usually fails on, rather than off, as it is the entire metal area of the airbag mount with some very thin plastic spacers that prevent it from constantly honking.
It failed on due to blunt force trauma. So its dafe to say those spacers are dead. Would you happen to know if theres enough depth behind the spokes to locate buttons there?
#4 | |
The lower portion of the side spokes have enough space for a push button switch.
Awesome thanks, hafta pick some up
| Yaris Horn install 15 Mins, WOLO 380 2T, Stock is too weak. | WRX | Third Gen Yaris General Discussion | 2 | 04-19-2014 11:07 PM |
| DIY Horn Replacement. | screenprintr | DIY / Maintenance / Service | 9 | 12-29-2012 02:29 AM |
| NRG and still have horn button?? | Jerkratt | Cosmetic Modifications (Exterior/Interior) | 9 | 04-08-2011 09:42 AM |
| FOR SALE: Steering wheel, shift knobs and Horn Button. | Yaris T-Sport | Items for Sale by private party | 15 | 11-11-2009 10:54 PM |
