Old 11-09-2014, 06:47 PM   #1
Eduardo_mty
2015, Reverse wire?
i need help to identify the reverse wire on 2015, france made it.
Eduardo_mty is offline   Reply With Quote
Old 11-09-2014, 09:28 PM   #2
On the French made 3rd gen the reverse wire is a red wire on the bottom row of that connector 5 pins from the left.
Old 11-09-2014, 09:30 PM   #3
Eduardo_mty
Its the wire that i marked?
CTScott, do you need a better picture? i will try it
Old 11-09-2014, 09:44 PM   #4
No. It is not that one. That actually might be the incorrect connector. The one you are looking for has the larger hole on either end with 12 smaller holes between.
Old 11-09-2014, 09:53 PM   #5
Eduardo_mty
I only see 3 red wire, if you see in this pictures, please tell me
Old 11-09-2014, 09:59 PM   #6
Eduardo_mty
This harness is in the left foot
Old 11-09-2014, 10:13 PM   #7
Eduardo_mty
pictures resized
Old 11-09-2014, 10:15 PM   #8
It is not available on any of those connectors. It goes from the transmission to a connector in the under hood fuse box to a connector on the face of the under dash fuse box to a junction connector in the hatch area.
Old 11-09-2014, 10:20 PM   #9
Eduardo_mty
do you have a pícture or wiring diagram....
i understand, that i will check in motor area?
can i connect between, the fuse and fuse box...
Old 11-09-2014, 10:24 PM   #10
You can grab the wire on the under dash fuse panel.
Connector 3C-33 or 3D-28
Old 11-09-2014, 10:28 PM   #11
Eduardo_mty
I Will tray tomorrow, thank you, thank you so much
Old 11-09-2014, 11:52 PM   #12
ucsmfu
Drives: yaris le
Eduardo_mty are you doing a reverse camera install ?
Is it possible to just tap to the reverse light wire?
Thanks
ucsmfu is offline   Reply With Quote
Old 11-09-2014, 11:56 PM   #13
Eduardo_mty
Yes, i will try to install the reverse camera.
I try to avoid to run wire from reverse light.
But i will do
Old 11-10-2014, 12:53 AM   #14
ucsmfu
Drives: yaris le
But i will do
I will be installing mine on Tuesday :)
Along with a autodimming mirror :)
Old 11-15-2014, 09:40 PM   #15
Eduardo_mty
i "found" another harness,...
lef picture harnes driver side, right picture left tail light
ctscott any help
Old 11-15-2014, 09:56 PM   #16
That's the right area. Look for the connectors shaped like 3C and 3D.
For the taillight, the service manual shows the backup bulb as being fed by a red wire for power and a white/black for ground.
Old 11-15-2014, 09:57 PM   #17
Eduardo_mty
How i will identify wich is 3c or 3d
Old 11-15-2014, 09:58 PM   #18
By the connector diagrams I posted above. Each connector has a unique shape.
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 02:20 AM
Scion XD LED mirror install pics aplenty enviri DIY / Maintenance / Service 76 07-21-2019 03:10 PM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 09:53 PM
ANYONE know where to tap reverse wire for ntd? marcus Performance Modifications 10 11-23-2009 01:28 AM
Reverse Lights Wire Color? NateDogg In Car Entertainment + Electronics (audio / video / alarm) 0 02-01-2009 07:03 PM
