#1 | |
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
Evaporation canister failure due to defect
saw it posted on truedelta.com
Edit: never mind. I found it: TSB T-EG048-07 When I searched for Evaporation canister, nothing showed up. Apparently, it was filed under vapor canister, LOL. Last edited by jack black; 11-13-2014 at 09:01 PM. |
OK, according to the TSB T-EG048-07 (available on the microimage USA.zip file), there is an improved Fuel Tank Filler Pipe Cover Holder (PN 77248–52060; $8 part).
Now, according to the newer T-SB-0024-11 (available free online) there is also new and improved Fuel Tank Filler Pipe Protector (PN 77277–52080; $40 part). But, there is also the newest TSB-0016-12 dealing with the same problem: TO PREVENT INTRUSION TO FUEL FILLER PIPE COVER, BY WATER OR DEBRIS THROUGH FRESH AIR INLET, A FILLER PIPE PROTECTOR WAS CREATED. Unfortunately, I can't find the newest TSB online. Does anyone have a copy of it? Has anyone replaced those parts to prevent the $800 canister from going bad. Or do you just wait for it to go bad? How water gets in the canister in the first place? Due to rain? |
TSB-0016-12 is only for the 07-11 Sedan and is basically identical to T-SB-0024-11 for the hatchback.
T-SB-0016-12.pdf
Thanks!
