Old 11-24-2014, 12:56 AM   #1
marcar72
Drives: 2014 Yaris L 5spd
Gasoline question...
... what do you guys think? Fuel up with 87 octane with 10% ethanol added, or fuel up with 91 octane pure gas? The 91 octane pure gas is about $0.50/gallon more.
I fueled up with 87 octane pure gas for the first time today (was in a different town somewhat far away) and man does the engine sound more quiet!
marcar72 is offline   Reply With Quote
Old 11-25-2014, 06:39 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Unless you are racing just get the cheapest gas you can find. This car seems to work on anything. I hit 50 mpg on the crappiest gas in my area, and haven't been able to hit it again with other gas.
Colin Chapman disciple
Old 11-26-2014, 07:49 AM   #3
roxy1
Drives: 2014 yaris 5 speed
you will get better mileage with the ethanol free gas, but not enough to cover the $0.50 per gallon. even at 42 miles per gallon vs 38 miles per gallon, and at $3.50/gal vs $3.00, you'd get 12 miles per $1 vs 12.66 miles per $1. I cant imagine any performance benefit in a yaris.
roxy1 is offline   Reply With Quote
Old 11-26-2014, 08:16 AM   #4
nortonfb
Drives: 2007
The ethanol if you have a higher mileage vehicle may cause more dirt in the system.
It can break residue in the tank loose.
Personally, I stay away from it though it may cost a little less. I never figured it per mile
Norton
nortonfb is offline   Reply With Quote
Old 11-26-2014, 11:19 AM   #5
why?
why?'s Avatar
Drives: Yaris LB
Only if the car is stock. If it is not stock then of course there could be reasons to run better gas. No one would put the cheapest 87 octane into Garm's old car.
Old 11-27-2014, 03:55 AM   #6
Yaris_Lover
Drives: 2012 Toyota Yaris SE
Speaking of gas I was wondering when you guys gas your yaris does the pump stop often? Like when you put it in and gassing then it stops without you stopping it and the tank wasn't full yet... Sorry thank you if you guys can help!!!!!
Yaris_Lover is offline   Reply With Quote
Old 11-27-2014, 04:34 AM   #7
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
Yes, I experience the same thing. I find the nozzle has to positioned in a certain position to prevent the auto stop back pressure system continuously releasing the trigger.
I've just learned to live with it,
mrpj is offline   Reply With Quote
Old 11-27-2014, 06:28 PM   #8
jcboy
Drives: Sedan 07
Norton
correct. the ethanol loses some power (Joules) and more expensive fuel has more additives for cleaning. the octane is actually BS for the average consumer who doesnt change the engine's compression ratio. (octane=resistance to detonation/early combustion)
probably just a more sensitive venturi valve on the nozzle or our tanks have smaller-diameter filler necks. in most cases it doesnt signify anything wrong.
License Plate question awebb005 Cosmetic Modifications (Exterior/Interior) 5 11-11-2014 08:28 AM
Natural Gas Transportation - Why Not? Kal-El Off-topic / Other Cars / Everything else Discussions 1 03-20-2011 01:12 PM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
