![]() ![]() ![]() Join Date: Sep 2014
2015 , Rear Fog Light
This car was made in France , so I guess that if you are ready for use the rear fog light ,
anyone know what the cable or fuse should I use |
Wich is the wire fog light wire?
Not all are made with the support for the rear fog lights. There is a relay integrated into the body ECU for driving the rear fog if it is. The relay is buried deep in body ECU, so you can't actually look to see if it is present.
There is a separate fuse for the rear fog in the under dash fuse panel: 7.5A FOG RR With the fuse present and the rear fog switch on (or it will also automatically turn on if the front fog switch is on) power will be applied to the green wire in pin 3 of connector 3D (I believe I posted the diagram of that connector in one of your other threads).
Thank you CTScott.. The driver interior fuse box, do not show a fog RR.
In that case, there is likely a significant harness change for the ones with rear fogs.
![]() Drives: 2010 Blue Yaris LB Join Date: May 2010
I have a 2010 LB Yaris. I found that when I pulled the fuse to disable the AC that the rear fog button would no longer light. The rear fog still worked but no indicator light.
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
It seems that the gen 2 is closer related to the gen 3 than the gen 1, but I doubt that this allows any serious assumptions about the gen 3's wiring ;)
I drive, therefore I am. |
He is talking about rear fog lights, not the rear defogger...
| Any PICS of Fog Light SWITCH Location?? | TRDMarty | General Yaris / Vitz Discussion | 7 | 05-29-2012 03:00 PM |
| Fog light jumping question | netz2008 | DIY / Maintenance / Service | 1 | 01-16-2012 09:55 PM |
| Finally installed oem ebay fog light for hatchback | Adriaan | General Yaris / Vitz Discussion | 6 | 12-27-2006 04:24 PM |
