Old 01-08-2015, 05:18 PM   #1
riddles
Drives: yaris t1
weird hard to explain noise
Hi
I have a 07model every morning when I start my car I here a noise coming from the engine it sounds like it's coming from around the belt area . It's not a squeaky noise. It comes on for like 30seconds then goes away once the car is warm. If I switch of the car and let it rest for for a few hours, when I start it again later the noise comes back. If my engine is warm I don't have a problem, it's only when the car has been resting for a while.
Can any one please give me a solution?
riddles is offline   Reply With Quote
Old 01-08-2015, 05:43 PM   #2
Kar98
Drives: 2011 Scion tC
Check your belt.
Old 01-08-2015, 05:47 PM   #3
It is most likely the belt slipping.
Old 01-12-2015, 06:04 AM   #4
John Lenin
Drives: 2009 Toyota Yaris 3-Dr HB Auto
Could be loose airbox too ... I have a "rattle" type noise coming from under hood on the driver's side ... does not sound metallic and occurs with car at high idle (i.e. cold start-up), or when stopped with trans in "D" & holding car with brakes ... popped the hood and grabbed the airbox with both hands and the rattle went away ... just have to figure out how to tighten 'er down!
John Lenin is offline   Reply With Quote
Compilation of Yaris TSBs eTiMaGo DIY / Maintenance / Service 72 07-04-2024 10:36 AM
Weird noise upon turning hazzy DIY / Maintenance / Service 3 07-08-2011 07:07 PM
Rear window sedan crackling noise. krolos General Yaris / Vitz Discussion 3 04-09-2011 12:39 AM
07 yaris weird engine noise mr07yaris General Yaris / Vitz Discussion 22 07-21-2010 08:33 AM
Metal on metal rotating wheel noise phyrefighterjay General Yaris / Vitz Discussion 7 04-19-2010 11:31 AM
