If Its Not Blown It Sucks
Will the prius engine bolt up??
I've read about the piston swap but what about the whole engine? Can the block be bolted directly to the yaris transaxle? Isn't the electric portion just an add-on between the engine and transmission? Just thinking if one could just throw a junkyard Prius engine ( high compression) under the hood and bolt up the ancillaries.
Mr. 155 and climbing
this question would require knowing whether or not you are talking auto or manual.
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
How about the Atkinson process and the iirc low torque on low RPM?
The prius has a CVT to be able to run at high enough RPM most of the timr and sone electric torque support.
I drive, therefore I am. |
You guys clearly have no clue on how the Toyota Hybrid Synergy Drive works.
The prius engine is not simply a high compression engine, it uses high compression pistons to compensate for the simulated Atkinson cycle the camshafts create. The transaxle is only continuously variable because it has 3 inputs into a planetary gear set, the ICE, MG1 and MG2. Yes, the engine will "bolt up" to whatever yaris transmission you want because its the same 1NZ block but the computer will not be able to run it. |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
Yes they do bolt on, 13:1 comp
I Drive a 129whp Yaris ;) |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Prius Pistons | sdyaris | Performance Modifications | 118 | 04-02-2013 01:38 AM |
| 1kr-fe engine wiring | boothybunch | DIY / Maintenance / Service | 0 | 03-28-2011 03:59 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
