Old 01-18-2015, 09:45 PM   #1
CharlieBravo
CharlieBravo's Avatar
Drives: 2007 Yaris HB
Troubleshooting RCAs
So I have 2 amps: one for the 4 cabin speakers (2 front, 2 rear) and one for the sub.
I upgraded the sub amp recently (swapped to higher watts); and when I tested it out, there was no sound from the sub. The cabin speakers were fine.
Light on the amp comes on (indicating power) and I measured ~12.5v (engine off) across the power-ground inputs.
With power to the amp, I pulled the RCAs coming from the HU and inserted a pair coming off my phone (headphone jack to RCA). Sound could be heard from the sub.
I really doubt the RCA cables are bad, since they were working before with the previous sub amp.
So do I need a new head unit or is there something else I can try?
Opinions/comments welcomed!!
CharlieBravo is offline   Reply With Quote
Old 01-18-2015, 11:35 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Make sure the Sub level is turned up if it's hooked up to a sub output on the deck.
Old 01-19-2015, 08:02 AM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
Your cables could have gone bad from pulling out the old amp.
Old 01-19-2015, 08:16 PM   #4
CharlieBravo
So its not the cables...
HU has 3 sets of RCA outputs: Front, Rear, Sub. I unplugged the Rear set and plugged in the pair from the sub amp. I got sound!
So now its definitely the HU Sub RCA outputs that are bad.
Know how to fix?
Old 01-20-2015, 12:47 AM   #5
Bluevitz-rs
so you made sure the level is turned up on the sub output?
Old 01-20-2015, 08:32 AM   #6
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Did you try to put back your old amp?
D.
CLA 250, 4MATIC
Old 01-20-2015, 11:36 PM   #7
CharlieBravo
Yeah, I made sure the sub level output on the HU was greater than 1 (range is 0-6).
HU is JVC Arsenal KD-A625.
No, I didn't try the old amp.
Help troubleshooting LED mirror turn signal JudgeM In Car Entertainment + Electronics (audio / video / alarm) 2 01-04-2014 01:35 AM
Need CLT troubleshooting advice gboezio DIY / Maintenance / Service 5 07-18-2013 10:49 PM
Troubleshooting Mix Bag! ras3448 Third Gen Yaris General Discussion 0 08-17-2011 03:49 AM
New Knu RCA'S & Speaker Wire....Wow (Knu is no joke) The Architect In Car Entertainment + Electronics (audio / video / alarm) 19 01-03-2010 12:38 AM
Are more expensive speaker wires and rca's worth it? raz1121 In Car Entertainment + Electronics (audio / video / alarm) 17 12-23-2008 11:55 PM
