Old 03-04-2015, 05:09 PM   #19
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Kinda looks like the oil used in AC systems.
2014 BSpec Divisional Champion
Old 03-04-2015, 05:42 PM   #20
Echo86
Drives: 2003 Toyota Echo
That's a person running and urinating to save time.
Echo86 is offline   Reply With Quote
Old 03-04-2015, 06:33 PM   #21
nortonfb
Drives: 2007
I noticed also on one of the Yari where I work PT.
No odor, no slippery feel.
I wonder if it could be windshield solvent?
Really need a larger sample.
Norton
nortonfb is offline   Reply With Quote
Old 03-04-2015, 07:09 PM   #22
Originally Posted by IllusionX View Post
I did not smell it, I'm sick anyways so i am unable to smell anything right now lol.
As WeeYari says, there are not paw prints anywhere, fresh snow this morning.
Can I test the AC system pressure with a tire pressure gauge?
No. It is too high of pressure and a special connector. You can watch for the fluid to move past the sight glass, with the engine running and the AC on. The sight glass is on the aluminum tubing on the passenger side, under the hood.
Old 03-04-2015, 11:28 PM   #23
CoryM
Drives: 2009 5-door, 5-speed
If you have a black-light it should make it glow nice and bright if it's A/C oil/dye. And yes, it sure looks like A/C oil. Look at the bottom of your A/C compressor, it's probably wet with it.
Cheers.
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 10:07 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 11:42 AM
Amsopil transmission fluid two thumbs up! Toolaholic DIY / Maintenance / Service 5 09-11-2015 12:35 PM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 06:18 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 11:57 PM
