Old 03-09-2015, 09:18 PM   #1
BobTheYaris
BobTheYaris's Avatar
Drives: '08 Yaris HB 2 dr
Should I Change Head Gasket?
Im going to be replacing my timing chain sometime in the next few months. The cars sitting at 134k miles and other than a noise on the belt side, probly worn chain/guides, the car runs great. Am I being overzealous by going a little farther and doing the head gasket while Im nearly there? Or am I just waisting my time and a little money?
Sent from my iPod touch using Tapatalk
BobTheYaris is offline   Reply With Quote
Old 03-09-2015, 09:31 PM   #2
Flammable
Flammable's Avatar
Drives: 2012 Yaris SE
I didn't realize changing a timing chain required so much tear down. Head gasket replacements are pretty involved so unless it is blown personally I don't see the point. Good luck
Flammable is offline   Reply With Quote
Old 03-09-2015, 09:34 PM   #3
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I don't even see it necessary to change the timing chain.
Old 03-09-2015, 10:36 PM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Timing Chain yes...head gasket no.
Old 03-10-2015, 11:09 AM   #5
tmontague
tmontague's Avatar
If you have to time and you want to now more about the engine then I'd say go for the head gasket. Since you'll have the head removed you can also clean the cams and head for any lsudge build up.
If you already know how the engine works/have no interest in it or are short on time then I'd just change the chain. I'm interested in what is making the chain so noisy as they usually last the life of the car in the 1NZ engine. I'm doing a valve job/sludge removal/head gasket on my fiancees '02 Echo and I'm not bothering with the chain as it sounds fine, I'm curious as to what kind of shape yours is in?
Old 03-10-2015, 02:22 PM   #6
bronsin
bronsin's Avatar
A busted TC on an engine of that mileage would be highly unusual. A bad head gasket even more so.
I would have another authority confirm the chain before proceeding...
Old 03-10-2015, 04:38 PM   #7
The 1NZ is a naturally noisy engine. Mine has always had taps and rattles which used to lead me to believe I had valve and chain issues. That is until I learned on this forum that these noises are normal. Had gotten used to the silence of a timing belt.
Old 03-10-2015, 05:22 PM   #8
Flammable
Flammable's Avatar
I concur, my 2012 Yaris' engine was noisy brand new and still sounds the same. Toyota tech at dealership said it sounds perfectly fine.
Old 03-12-2015, 09:51 AM   #9
canadian deacon
Drives: 2014 yaris 5dr
The head bolts for the Echo require a double hex bit. It looks like a T-5 Torx bit but is not. Snap-On sells the proper bit (8 mm, I think but it's best to check).
If you choose to do the head get the proper tool.
I am assuming the Yaris uses the same head bolts.
canadian deacon is offline   Reply With Quote
Old 03-12-2015, 10:19 AM   #10
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
X2 The head bolts are a double hex 8MM. I'm at an auto wreckers pulling a head as I type this.
Old 03-12-2015, 10:51 AM   #11
Dom's?
Old 03-12-2015, 10:51 AM   #12
Bluevitz-rs
Yup
Old 03-12-2015, 11:01 AM   #13
Oh what memories of keeping junkers alive during my high school days, and the times spent at Dom's.
Head/ TB / Spacers / Turbo and Other thing xbgod Items for Sale by private party 33 11-08-2010 12:52 AM
Another 2010 head gasket oil leak found ... Hershey General Yaris / Vitz Discussion 4 10-20-2010 01:18 AM
GO FOR IT ? Trade 2010 3 door ( W/oil leaking head gasket ) for 2010 sedan Hershey New YARIS Purchase Forum 9 10-10-2010 02:06 AM
Changing LED's In Projector Head Lights whooppee777 Cosmetic Modifications (Exterior/Interior) 16 03-01-2009 03:07 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
