Old 03-27-2015, 03:41 PM   #1
MJZ
Drives: 2008 Yaris 3 Door Manual
Question What does this bulb do in the headlight?? (DRL Problems?, *SOLVED* Thank you!*)
What in the world does this bulb do? I replaced both of them. Yet, Nothing I do makes them turn on... WTF are they for?? TOTALLY confused...
The main bulb turns on for the DRL, gets a bit brighter when I turn the actual lights on and even brighter when I put on the high beams.
This light NEVER turns on...
MJZ is offline   Reply With Quote
Old 03-27-2015, 04:19 PM   #2
Yaristeve
Drives: 3-door hatch
From my experiments, they are the "parking" lights. IIRC, when you turn the light switch to the first stop, they are the only lights that go on at the front.
Where did you get the bulbs? One of mine burned out and (I'll admit) I am a little lazy to find the part number and a vendor (available at autoparts store?)...
Old 03-27-2015, 04:26 PM   #3
MJZ
Got them at Pepboys, don't recall the part number off hand.
Mine don't light up... ever, not even at the first click which should be the DRL's.... I get
DRL - Main bulb
Driving - Main bulb
High - Main bulb
On both sides, freshly replaced. I'm going to go turn them around to see if that makes a difference like if they "burn out" the DRL defaults to the main bulb.
Old 03-27-2015, 04:48 PM   #4
MJZ
Ok, so I went and checked them, no way they could be in the wrong way given the socket, looks like a 194 wedge bulb. Everything is connected proper, yet, they do not light up as DRLs, the main bulbs do.
Old 03-27-2015, 04:54 PM   #5
MJZ
Also, at first click, the rear lights do come on, just not the fronts...
Old 03-27-2015, 04:56 PM   #6
MJZ
Even with the light selector "off" when the DRLs are supposed to come on, the main headlights do, not these little guys.
Old 03-27-2015, 05:02 PM   #7
MJZ
Ok, so this page
CarCareKiosk says the main bulb on the 07-2011 Yaris **IS** the DRL.
So now I'm properly confused as to what that little bulb is and why it's not turning on.
Old 03-27-2015, 05:30 PM   #8
MJZ
Checked the fuses both fine (that one under the dash sucks to check being a fat guy, just sayin)
Old 03-27-2015, 05:53 PM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
Try this.. Turn off car, pull the handbrake, turn lights to first click.
Report back...
Old 03-27-2015, 05:58 PM   #10
MJZ
The yellow bulbs on the sides of the assembly are on (as are the rears) that is all.
Old 03-27-2015, 08:01 PM   #11
Yaristeve
How odd.
What year is your Yaris? I have a 2011 but there is no DRL or DRL setting on the headlight switch on mine. Plus, IIRC, the amber light does NOT go on (I will have to check this to be sure, tonight after work, though) when I turn the light switch to the first click.
Are you the original owner? Maybe the previous owner rewired the lights?
Old 03-27-2015, 08:53 PM   #12
MJZ
It's a 2008. It just came back from the shop after it was backed into (front end) could they have put the wrong lights in the wrong holes? Is that even possible?
Old 03-27-2015, 09:03 PM   #13
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
It's a 194 bulb I use led style replacement bulb 6000k and they look awesome they are park lights but stay on with main..ur bulbs are probably just burned out and as for DRL they light up ur main bulbs I have my DRL module unplugged the orange side are same size bulb too 194
Old 03-27-2015, 09:47 PM   #14
MJZ
Every bulb in both housings is brand new (less than 2 weeks old)
So it's not burnt out bulbs.
Old 03-27-2015, 09:50 PM   #15
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Hmmm...well they should work like I said and DRL have nothing to do with it next I would look at any problem with wiring and fuses etc
Old 03-27-2015, 10:02 PM   #16
MJZ
Checked the fuses #13 (a 7.5) in the engine bay and #15 (a 25 amp) under the dash and both were good to go.
Does anyone have a photo of what this SHOULD look like and the situation in which they light? When I disengage the e-brake the DRL's (main bulb) lights up even with the selector in the off position. No configuration or process of parking, pull the e-brake, flashers, signals, off, first position, on, high... nothing has illuminated these bulbs.
I checked the bulbs as well, not just assuming that since they were recently installed that this meant they were ok, the bulbs are both fine.
A bit flabbergasted at this point... Unless there is another fuse I've missed. But if normal operation of the Parking lights illuminates the forward facing bulbs that presently are not lighting up, the side facing that light up the yellow reflectors and the rear reds... and all are working except the 2 forward facing, would that point to a fuse?
Old 03-27-2015, 10:05 PM   #17
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Fuse or bulb problem from ur description
Old 03-27-2015, 10:13 PM   #18
MJZ
But if both fuses and both bulbs are fine? I checked, today.
Is there a different fuse that runs just those forward facing lights? Can you provide me with the fuse number/location?
Headlight bulb change....more to it than meets the eye... Yarflana DIY / Maintenance / Service 0 03-24-2013 08:56 PM
Where can I order a Headlight Bulb Rubber Boot online? JAM DIY / Maintenance / Service 2 12-08-2011 06:48 PM
headlight bulb bankrobber DIY / Maintenance / Service 2 08-06-2011 08:06 PM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 08:58 AM
DIY - A EASY&FAST way to change headlight bulb ALLBLACK DIY / Maintenance / Service 0 09-18-2010 01:40 AM
