Drives: 2008 Yaris Join Date: May 2012
Help findind a part for alternator
Hello,
I'm looking for the part that mounts the alternator adjust arm to the engine for my 2008 yaris. The tip of it broke off and I am currently using a bolt from a hardware store to keep it mounted. It works, but the belt alignment is off and its causing the belt to squeal. I don't know what to call the part. So, i'm not having any luck finding a replacement. Any help is appreciated. Thanks. |
![]() ![]() Drives: Yaris Join Date: Feb 2013
use http://www.toyodiy.com
insert your VIN and you will get ALL the parts name and reference... tell me if you are finding yourself with this wonderful website I just gave |
Post a picture
I had a bear of a time finding it, as it wasn't in the EPC with the alternator and wasn't called anything like what I was expecting.
The part is called "Bar, fan belt adjusting" and the part number is 16381-21030
| DIY - Carbon fiber wrapping | Brian | Wash, Wax, Detailing, Exterior Repairs | 15 | 07-10-2016 12:34 PM |
| Need help finding the Japanese part number for the TRD Sway Bar (PTR11-52071) | chalked | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 01-26-2013 02:29 PM |
| Alternator Part # question | 09sedan | DIY / Maintenance / Service | 2 | 05-29-2012 12:20 PM |
| 2008 OEM S model Liftback Lip kit Part numbers | PETERPOOP | Cosmetic Modifications (Exterior/Interior) | 17 | 07-26-2010 01:33 PM |
| NEED HELP - Yaris suspension part | Trish | General Yaris / Vitz Discussion | 10 | 11-07-2009 01:44 PM |
