Yaris to Echo Strut swap
Does anyone know if the rear and/or front struts on a '08 Yaris are compatible with an '02 Echo? The Echo's rears are leaking and the ones I just took off my Yaris are still in great shape so I'd love to swap them. The rears look exactly the same, the front's are what I'm really not sure about.
#2 | |
From 2009
does that go for front and rears?
nvm, just checked at rockauto and both F&R's are different part numbers and look different. So much for saving on the suspension |
EDITED*
Just found the image I was looking for. Bolt sits on top of bearing and sub assembly then gets placed on top of that Does anyone have an exploded view of how an '08 Yaris front strut is supposed to be re assembled? The manual doesn't have an exploded view and I'm confused about the bearing and strut mount (sub assembly) specifically. The way I have it currently mounted look correct and it is function fine but for some reason I think I may have installed it wrong. I currently have it installed as follows: -bumper, boot and upper spring coil seat ontop of the spring -bearing and mount (sub assembly) then placed on top (with the bearing underneath the mount) -nut bolted on top -strut installed in tower and then top mount and bolt tightened to secure it. What I'm wondering is does the bolt go directly on top of the bearing and then the sub assembly just placed on top, or am I correct with bolting down the sub assembly and bearing together? Last edited by tmontague; 03-31-2015 at 01:07 PM. |
| ) strut bars for yaris ( | aucorium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 09-14-2010 12:18 PM |
| Echo and Yaris fan forum | jambo101 | General Yaris / Vitz Discussion | 7 | 01-26-2009 12:27 PM |
| Yaris Vs ECHO Quality | bronsin | General Yaris / Vitz Discussion | 15 | 12-11-2008 08:57 AM |
