Old 03-30-2015, 08:46 PM   #1
jari93
Drives: Yaris sedan 2007
Brake problems?
Hi guys, I have a 2007 silver yaris sedan. When my car is slowing down and before I am about to stop, a noise comes from my front left (driver side) tires. This noise sounds like something is stuck while rotating with the wheel. However this noise does not appear all the time, only when I have been driving for 30 min or more. I do not know what it could be. Brakes? or something else?
jari93 is offline   Reply With Quote
Old 03-30-2015, 10:14 PM   #2
fourbangingfun
fourbangingfun's Avatar
Have you taken the caliper apart to see if the pad springs and the pads themselves are properly seated? It Would also be a good opportunity to take the rotor off to look for any pebbles that might be trapped. I posted a thread on here about a small rock that was stuck in my rotor. I Included a video to show the noise.
fourbangingfun is offline   Reply With Quote
Old 03-30-2015, 10:15 PM   #3
sheekeebut
Minimalist
Drives: 07 silver sedan
You've checked that wheel, right? I would have already jacked up that corner and taken the wheel off to see what's going on. Possibly something stuck to your rotor.
sheekeebut is offline   Reply With Quote
Old 03-30-2015, 10:16 PM   #4
sheekeebut
Minimalist
Caliper, sorry, fbf would make more sense there.
Old 04-02-2015, 03:33 PM   #5
jari93
Thank you guys I think there is something stuck in there to. I will check asap
Old 04-02-2015, 03:55 PM   #6
I had a grinding a few years back and discovered that one of these clips that slip onto one end of each pad had broken. Piece of it stayed lodged in there and was scraping against the rotor.
Old 04-02-2015, 08:18 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Always check callipers when cold not warm if sized ...
Old 04-03-2015, 11:30 AM   #8
Originally Posted by Exiwolfman View Post
if sized ...
if seized?
Old 04-03-2015, 11:39 AM   #9
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
if seized?
Yes ...lol
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
Problems with brake systems after rains. Blackstare DIY / Maintenance / Service 1 06-28-2014 08:16 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
2010 Prius brake problems easy fix. best video ever! dinamix Off-topic / Other Cars / Everything else Discussions 6 03-14-2010 11:00 PM
