Old 05-05-2015, 03:11 PM   #199
WorkTL
WorkTL's Avatar
Drives: 2013 Yaris LE
Thanks for the info! Where can I buy a Zage kit, sir?
WorkTL is offline   Reply With Quote
Old 05-05-2015, 03:12 PM   #200
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Try contacting Garm first. Cali_yaris.
Old 07-28-2015, 12:17 PM   #201
Tarmat Terror
Drives: Ncp13-2001
Lightbulb Engine Swap
Hey guys new to the mod world all the way from barbados , but i have a question , does anyone know if a 1zz engine can bolt into my Ncp13 which is the Vitz model right hand drive from japan and if any fabrication needs to be done and what would they be . thanks.
Tarmat Terror is offline   Reply With Quote
Old 07-28-2015, 12:31 PM   #202
Tarmat Terror
Drives: Ncp13-2001
Originally Posted by Attitude View Post
Hello
ive got vitz with 1szfe, i am willing to swap the engine
the available engines in my country is 1nzfe, are you people in favour of that ? it comes bolt on, no issues
please reply thanks
yes thats fine the rs versions have in the 1nz-fe
Old 07-28-2015, 12:33 PM   #203
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The frame needs to be cut for clearance on the pulley side of the engine.
Old 07-28-2015, 12:58 PM   #204
Tarmat Terror
Drives: Ncp13-2001
hey i'm looking to do a swap i have in a 1nz-fe and i want to put in the 1zz did you have to modify anything or was it just a bolt in ? or did your echo come with that engine?
Old 07-28-2015, 01:00 PM   #205
Tarmat Terror
Drives: Ncp13-2001
hey can you explain more ? cut the frame how ? and can my 5spd 1nz-fe gearbox fit on without changing bell housing ? can you give a me a step by step??
Old 07-28-2015, 01:27 PM   #206
Bluevitz-rs
The motor is bigger so you have to make room for the belts an pulleys. You would have to change bell housing on the transmission too.
Old 07-28-2015, 02:18 PM   #207
Tarmat Terror
Drives: Ncp13-2001
so what would be better to do one time ? a 1zz or 2zr i need your knowledge if they both are the same amount of fabricating i would go big one time
Old 07-28-2015, 05:47 PM   #208
Bluevitz-rs
The 1ZZ was never an option for any NCP chassis as far as I know. I don't know much about the 2ZR as far as size but it was an option in 2006+ Yaris so it might be a little shorter than the 1ZZ.
Old 07-28-2015, 06:12 PM   #209
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Let me chime in 1zz is possible with no cutting to fit it, but not a great swap cuase of the fabrication involed and wiring rather drop a 2zz.... The 1zz tranny or housing is required. Cutting the chassis is required if you are planning on a 6spd...
The 2ZRFE is almost a drop in swap and you can use the stock tranny...
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 07-28-2015, 06:16 PM   #210
Bluevitz-rs
Let's make sure we're on the same page here. They're talking about a fist gen chassis.
Old 07-28-2015, 06:20 PM   #211
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Ooooh! ok So it's the other way around, 1zz wiring is similar to the first gen as the ECHO we get here in PR and its the almost the same demensions 2zz swaps are around
R-CaT
Project Yar 2ZR
Old 08-01-2015, 11:53 AM   #212
Tarmat Terror
Drives: Ncp13-2001
Thanx for the advice so far guys it was helpful im going to do the swap and turbo charge but can i put on a 6spd box without and fabrication?
Old 01-24-2016, 09:49 PM   #213
Dr.DevILL
Drives: 2010 Yaris LB
Bringing this thread, back from the dead...
in all honesty, I've read about a RAV4 2ar being used to churn out some serious hp in a TC (approx. 800) anyone consider a 2ar swap into one of our tiny cars? its a 2.5 so it'd be kinda cramped. just a seriously considered idea.
Dr.DevILL is offline   Reply With Quote
Old 02-17-2016, 01:38 PM   #214
tk-421
tk-421's Avatar
Drives: 5D-07-LB
in theory the 1.8L 2ZR-FE from the European-spec Yaris TS (and also the same engine as used on the new Corolla and Scion xD), as I highly doubt Toyota would have two totally different bodies for each engine. But, with "just" 130hp, it's not exactly worth the swap... unless it can be built up to much much higher levels, but I don't think that has been proven yet....
Looks like this has been confirmed and well documented:
http://www.yarisworld.com/forums/showthread.php?t=56031
Old 03-17-2016, 08:03 PM   #215
Frank the Tank
Drives: 2007 Toyota Yaris
What would be needed in order to do a b18c or k20 swap?
I like the idea of having a honda engine with a LSD transmission.
Frank the Tank is offline   Reply With Quote
Old 03-17-2016, 08:27 PM   #216
fnkngrv
fnkngrv's Avatar
I would really love to see an 8ar-fet swap....that would be awesome
Sent from m-o-b-i-l-e
Official POLAR WHITE yaris thread wushumasterku Photo-Video-Media Gallery 477 08-27-2023 04:01 AM
