Old 05-16-2015, 02:26 PM   #19
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Originally Posted by IllusionX View Post
I just came back from the garage to get the gasket replaced.
I was warned at the dealer that aftermarket gaskets won't fit. Well, I got the one from RockAuto, and its slightly too big.
And they don't last ....use Toyota one
Old 05-16-2015, 02:39 PM   #20
IllusionX
Drives: 07 Yaris Sedan Aero
Its working for now. I will change it next year since the bolts are no longer rusted. I will be able to change it myself.
Old 05-16-2015, 03:25 PM   #21
tmontague
tmontague's Avatar
I noticed the ones I got from RockAuto are not snug like the original one. I still installed mine and noticed no issue or smell on my Yaris. I'll leave it on and in 80,000km i'll replace with an OEM one.
Old 05-16-2015, 08:53 PM   #22
Exhaust smell in cabin
My replacement gasket purchased from Napa. No fitment issues with it.
Old 05-17-2015, 11:42 AM   #23
"G"
Drives: 2007 Yaris Hatch
You buy cheap you buy twice. I would never buy a part like this from Rockauto. Furthermore you do not want to heat up the bolt. You heat up the manifold so it expands.
"G" is offline   Reply With Quote
Old 05-18-2015, 08:32 PM   #24
"G"
My original gasket lasted 188,000 miles, not bad at all. My initial suspicions were correct. It was the gasket. Here is what was left of it and the bolts that came out. Slow cycles of heat and a steady hand. Thanks for the peeps who confirmed my problem.
Old 05-18-2015, 08:54 PM   #25
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Good job. You'll probably find you get better mileage now too.
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 10:08 PM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 09:02 AM
Enkei's and Dunlops + Medalion Touring Exhaust 2manywheels Items for Sale by private party 40 04-04-2011 06:01 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 10:23 PM
