![]() ![]() Drives: 07 Yaris 4DR Join Date: Jun 2009
How to remove console by parking brake in hatchback?
Trying to determine if my Yaris has an existing AUX cable that I just need the plug, or the entire assembly to plug into the OEM unit. I did a few searches, but couldn't find a guide to remove the console by the parking brake in a hatchback.
![]() Also, would anyone know before I pry it open, if my unit supports AUX?
I don't think your unit supports AUX. From what I've seen, units capable of supporting it have an AUX button on the face.
To remove the console, remove a bolt/screw located in the bottom of the cup holder. If you then lift up on the rear of the console, it will release itself from some retaining clips.
Correct - That headunit is not directly compatible with the OEM Aux jack.
Thanks guys. I ordered a new head unit + trim + wire harness from Crutchfield.
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| The brake story: frequent disk warpage | Lux | DIY / Maintenance / Service | 20 | 11-01-2014 12:25 PM |
| Question replacing head gasket. | Snyprwlf47 | DIY / Maintenance / Service | 3 | 07-13-2014 11:17 PM |
| 09 hatchback black console | jeremyshay | Cosmetic Modifications (Exterior/Interior) | 1 | 01-15-2009 02:30 PM |
